B20Z Head same as B18B?
Old Sep 6, 2001 | 10:11 AM
Chuji's Avatar
Default B20Z Head same as B18B?
Is it possible to put a B20 head on my 96 B18B? I bend a few valves and my friend has this head lying around what all do I need to put it on or is it a direct swap? Thanks
Old Sep 6, 2001 | 10:48 AM
Speed PHreak's Avatar
Default Re: B20Z Head same as B18B? (Chuji)
yup, same head if i'm not mistaken. you may want to check out b-20.net or crvtec.com......
~steven
Old Sep 6, 2001 | 11:42 AM
optiontoo's Avatar
New User
The B20 head has a little more port volume than the B18 head... it's a power builder. I'd re-use the LS cams though.
Old Sep 6, 2001 | 04:42 PM
non-VTEC's Avatar
i think the accualy combustion chambers on the CRV head are slightly larger due to the fact that the CRV block has 84mm pistons.
Old Sep 6, 2001 | 05:25 PM
optiontoo's Avatar
New User
Default Re: B20Z Head same as B18B? (non-VTEC)
Negatory. Combustion chambers are the same. They "should" be larger for the larger 84 bore, but they aren't. Cost cutting at its finest.
juicedricer
19
Jan 19, 2011 08:37 PM
DA chosen 1
May 23, 2006 09:46 PM
DAfireman
Nov 25, 2004 10:17 AM
LSBeast
10
Sep 17, 2002 06:44 PM
Hybridhonda10
Apr 3, 2002 01:31 PM
