HUB BORE...is it all the same for honda's?
Old Oct 31, 2003 | 09:08 AM
phantom_sol's Avatar
Default HUB BORE...is it all the same for honda's?
i searched and i am trying to get hubcentric rings from prestigewheel.com but i need the hub bore on the rotas i'm putting on. ont he box it says
HB: 67.1
thats the hub bore right? well i go this...
"Payam as far as i can tell by the info you have given me, it sounds like that is the dimension of your vehicle hub bore, not your wheel hole size.
To: Web Sales Customer
Fr: Prestige Sales Dept.
ok.... is he saying that 67.1 sounds like my hub diameter on my car? because i think that the 67.1 is for the bore of the wheel. i dunno. can someone enlighten me?
i have 99-00 civic si knuckles on a 93 del sol s. if that matters. are hub diameters all the same for hondas? or are there diffrences.... i checked in my honda del sol service manual but i couldnt find anything....
Old Oct 31, 2003 | 09:37 AM
UP?
Old Oct 31, 2003 | 12:54 PM
kommon_sense's Avatar
Default Re: (phantom_sol)
hub diameter on civs and tegs is 56.15.
http://www.prestigewheel.com/HubRingsbyMake.asp
Old Oct 31, 2003 | 01:19 PM
civicminded92's Avatar
Default Re: HUB BORE...is it all the same for honda's? (phantom_sol)
Why not go directly to rota to get them and save yourself some trouble - $20 shipped.
Hub hole size on rota's: 67.1mm
Civic hub size: 56.15mm
There ya go.
Old Oct 31, 2003 | 01:22 PM
Default Re: HUB BORE...is it all the same for honda's? (civicminded92)
does rota use metal,plastic or composite?
Old Oct 31, 2003 | 02:07 PM
ScrapinSi's Avatar
Calipers are your friend...
Old Oct 31, 2003 | 02:13 PM
The Internet Tough Guy's Avatar
Default Re: HUB BORE...is it all the same for honda's? (ScrapinSi)
the hubrings you want are 67.0mm x 56.15mm
your wheel is 67.1 but 1/10th of a mm is very very small and allows the ring to fit snugly but not forced on the wheel.
http://www.prestigewheel.com has em. 30 bucks.
also they are composite so they wont melt or sieze on the hub.
Old Oct 31, 2003 | 03:00 PM
hayabusa160's Avatar
Default Re: HUB BORE...is it all the same for honda's? (jwn7)
what size rota u have? caz i got 15 inch rota hub ring and they dont fit my 16 inch rotas they are too small
Old Oct 31, 2003 | 04:46 PM
Default Re: HUB BORE...is it all the same for honda's? (hayabusa160)
i have 15s. yes the 16's centerbore is most likely bigger. it says on the box and inside the wheel.
Old Nov 3, 2003 | 07:10 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phantom_sol &raquo;</TD></TR><TR><TD CLASS="quote">does rota use metal,plastic or composite?</TD></TR></TABLE>
I am unsure about materials used in Rota's rings. I was considering getting some rota's at one time and researched it. I ended up getting Kosei K-1 racing wheels (15") from tirerack. They came with plastic hubrings.
The real reason I would go with the manufacturer's rings is because the SHOULD take into account wheel construction - and chamfers or radii that are part of the wheel. In other words, the rota rings should fit the wheel properly.
Old Nov 3, 2003 | 10:36 AM
rota's website looks like it was made by an 8th grader for a webdesign project
jmai86
Mar 23, 2012 11:17 AM
ahloung
Northern California (Sales)
Mar 12, 2006 09:41 PM
Will SR20
Oct 27, 2004 05:57 AM
RAB
Aug 11, 2002 06:41 PM
