Brakes creak after pad change...retaining clips??
car: 96 civic ex
problem:
I recently changed my front brake pads. I put the non squeal stuff between shim and pad. I DIDN'T use silicone grease on the pad retaining clips, nor did I take them off and inspect them.
Now when I brake, and only when I brake, just from the left side I hear loud creaking. it's oscillating too. My rotor is in perfect condition and nothing looks damaged around the area.
Do you think I need to grease the retaing clips like the Haynes says so?
CLIFF NOTES: Oscillating brake creaking, could it be that I didn't grease brake pad retaining clips?
problem:
i fixed it. it was the brake pad retaining clips. I simply put a light coat grease on them and everything is perfectly silent. As for resurfacing rotors... why? they are in great condition. It stops quick, smooth, and evenly (doesn't drift to side)
vtecn8ive
Mar 6, 2006 02:28 PM
integra0260
Oct 21, 2001 08:09 AM
