oil pan??
does anyone know if someone makes a smaller or shorter oil pan for the H22...my oil pan is real close to the ground on my EG...the car isn't "that" low....has anyone had issues with it or am I looking too much into it....I just know my d series oil pan got a pretty beat up in my last hatch...but I guess I wont be dumped on air this time....but I could adjust my ride height to make for perctly happy little axles...hmmmm
My pan is pretty close the ground as well, but my header protects it from harm mostly. Got hit once or twice. Just make sure you suspension is good and you should be fine.. I live in pothole heaven so if I can survive then so can you..
my pan is pretty low, in fact i cracked it one time.
but i've run over quiet a few things and i have bad shocks... so i bounce a whole lot.
we took mine off, welded it, and its holding up good so far. now im trying to get some good shocks...
but i've run over quiet a few things and i have bad shocks... so i bounce a whole lot. we took mine off, welded it, and its holding up good so far. now im trying to get some good shocks...
joshualeet
13
Oct 2, 2008 08:17 PM
