99-00 Si injectors the same as 98+ JDM ITR?
Old Oct 30, 2003 | 11:25 PM
ABTDer's Avatar
Default 99-00 Si injectors the same as 98+ JDM ITR?
does anyone know if 99-00 Si injectors and 98+ JDM itr are the same?
thanks
Old Oct 31, 2003 | 07:08 AM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
Community Influencer
Default Re: 99-00 Si injectors the same as 98+ JDM ITR? (GuerillaUnion)
All B series come with 240cc injectors. I'm sure its the same for JDM engines as well.
Old Oct 31, 2003 | 07:13 AM
baonest1's Avatar
Default Re: 99-00 Si injectors the same as 98+ JDM ITR? (ActiveAero)
i heard the JDM R's came with 270cc... but dont take my word for it
Old Oct 31, 2003 | 10:24 AM
ABTDer's Avatar
so there is nothing equivalent in any other USDM motors?
Old Nov 1, 2003 | 05:58 PM
AzG35's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ActiveAero &raquo;</TD></TR><TR><TD CLASS="quote">All B series come with 240cc injectors. I'm sure its the same for JDM engines as well.</TD></TR></TABLE>
This is correct, all B series injectors are the same. The only differences are OBD0 (peak and hold), OBD1 and OBD2 (both saturated)
Old Nov 1, 2003 | 06:21 PM
daddymaxx's Avatar
ok ok I work at honda. an dI checked this out. When I did my b18c-r swap I thought my d16 injectors would work. On the net it says that all d/b series are 240cc saturdated. Well this is WRONG.
But in my research I tracked down all the actuall part numbers and here's what I came up with.
99-00 B16a, 96-00 SOHC vtec, and b18c5 are the same.
B18b and B20 are the same, and B18c1 are different from everything.
So prett ymuch find any vtec injectors aside prelude and accords, and you're fine.
Old Nov 1, 2003 | 09:40 PM
K20EG's Avatar
Default Re: 99-00 Si injectors the same as 98+ JDM ITR? (baonest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by baonest &raquo;</TD></TR><TR><TD CLASS="quote">i heard the JDM R's came with 270cc... but dont take my word for it</TD></TR></TABLE>
Yea i heard that to
Old Nov 2, 2003 | 02:49 AM
MiraiZ's Avatar
Default Re: 99-00 Si injectors the same as 98+ JDM ITR? (K20EG)
JDM B18c (Type R) came with 290cc... I was suprised to learn this too. All these years, I thought I had 240's. But when I got my PFC tuned, the orinal size was set at 290cc. (this is hard-coded in the ECU, so my tuner did not change this)
Old Nov 2, 2003 | 09:10 AM
baonest1's Avatar
Default Re: 99-00 Si injectors the same as 98+ JDM ITR? (MiraiZ)
doh.. it was 290cc. it was MiraiZ who i heard it from. thats right.
Old Nov 2, 2003 | 12:50 PM
ActiveAero's Avatar
Paragraph Alert
25 Year Member
Community Builder
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MiraiZ &raquo;</TD></TR><TR><TD CLASS="quote">JDM B18c (Type R) came with 290cc... I was suprised to learn this too. All these years, I thought I had 240's. But when I got my PFC tuned, the orinal size was set at 290cc. (this is hard-coded in the ECU, so my tuner did not change this)</TD></TR></TABLE>
Dang it. Cheated again...
Old Nov 2, 2003 | 04:13 PM
paRRRker's Avatar
ill take this as the right answer...i mean he is from jdm land
Old Nov 3, 2003 | 09:00 PM
IN VTEC's Avatar
At what fuel pressure do they rate that flow at?
Old Nov 3, 2003 | 10:54 PM
sgT's Avatar
sgT
Default Re: (daddymaxx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by daddymaxx &raquo;</TD></TR><TR><TD CLASS="quote">ok ok I work at honda. an dI checked this out. When I did my b18c-r swap I thought my d16 injectors would work. On the net it says that all d/b series are 240cc saturdated. Well this is WRONG. </TD></TR></TABLE>
Thats funny, i am using 1992 civic DX injectors in my ITR motor and making 190 at the wheels.
psegs80
Jun 19, 2007 08:50 AM
bluesaint
Sep 26, 2006 06:58 PM
Hoodwinked
Mar 8, 2004 11:23 PM
jonas
Jan 1, 2004 04:36 PM
coquinn
Dec 21, 2001 11:28 AM
