noob question...sorry, i searched.
Old Oct 30, 2003 | 08:28 PM
Ryan C's Avatar
Default noob question...sorry, i searched.
i am building a GSR.
so far i have itr valve springs and retainers in the head (with new guides) and stock gsr cams.
and i am considering balancing my stock rods and adding ARP rod bolts and i am planning to uses itr pistons to raise the cr.
now my question is, i still use the stock p72 ecu right?
also could any one give me a ball park price for itr pistons?
and what would that setup raise my cr to exactly?
TIA fellas
Old Oct 30, 2003 | 09:33 PM
dirty_d_cx's Avatar
Default Re: noob question...sorry, i searched. (Ryan C)
i think that your cr would be around 10.84:1
try it yourself
go to http://www.c-speedracing.com and sroll down to the bottom of the page and click how-to
there is a section there called calculating compression ratios
good luck
Old Oct 30, 2003 | 09:40 PM
kill bill's Avatar
Default Re: noob question...sorry, i searched. (dirty_d_cx)
use ctr pistons, get a lil more HP out of the set up, price should be close to the same as ITR pistons. and u still retain the ability to use pump gas with ease.
Old Oct 30, 2003 | 09:49 PM
b19coupe's Avatar
$200 ballpark for pistons. About another $130 for rings.
Compression 10.8:1. Do yourself a favor-get Hondata, or at least a VAFC and get it tuned.
Old Oct 30, 2003 | 11:34 PM
PHiZ's Avatar
Default Re: noob question...sorry, i searched. (b19coupe)
You can get someone to draw you up a custom performance chip also.
But that is only like 100X times better than an AFC, and about on par with hondata.
-PHiZ
Old Oct 31, 2003 | 06:40 AM
Ryan C's Avatar
Default Re: noob question...sorry, i searched. (PHiZ)
ah ha...now this is where it gets tricky....
i am trying to do this on a "budget"
the reason i choseITR over CTR is because i am planning on doing a DP nitrous setup contolled by the JNMM. and i am pretty sure those few extra cr points from CTR's + n20 will lead me into some problems. I am trying to keep it as simple and cheap as possible with the hopes that within a year or so i can go turbo.
now i knew you guys were gonna say v-afc, custom chip, hondata ect.
but now that this turned into a BASIC nitrous set up, where hopefully AF will be controlled w/ propper jetting and timing will be pulled with the JNMM, now what do you think?
thanks guys
Old Oct 31, 2003 | 06:44 AM
b19coupe's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ryan C &raquo;</TD></TR><TR><TD CLASS="quote"> and i am pretty sure those few extra cr points from CTR's + n20 will lead me into some problems. now what do you think?
thanks guys</TD></TR></TABLE>
I think you may have problems.
And I think that N20 is not "all motor".
Good luck, though
Old Oct 31, 2003 | 07:09 AM
Ryan C's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b19coupe &raquo;</TD></TR><TR><TD CLASS="quote">
right you are...i didnt think this thread would get this far, sorry
if your a mod you can move it, sorry
GSRpoweredSI
16
Apr 26, 2007 06:03 PM
Drian
Feb 22, 2004 09:24 PM
TypeR0wnz
Feb 15, 2003 03:06 PM
rainmanEK
Jul 17, 2002 09:10 PM
prjctCIVIC
Jun 21, 2001 12:45 PM
