!!!!!!!!!!!!!!!!!! ALRIGHT, PLEASE I NEED TO KNOW QUICK !!!!!!!!!!!!!1
Old Oct 30, 2003 | 07:11 PM
98BlackEX's Avatar
Default !!!!!!!!!!!!!!!!!! ALRIGHT, PLEASE I NEED TO KNOW QUICK !!!!!!!!!!!!!1
Ok,,, I've got an appointment tommorow morning at a local performance shop to get Nitrous Installed on my Stock 98' Civic EX, with a SOHC d16 engine. And, I need some professional help, as to IF my CIVIC will be able to handle a 50-75 shot of nitrous, WITHOUT tearing something up.
I don't wanna waste my time and money, just to blow something up (Head gasket, burnt valve, etc.) the very FIRST time i spray it. So, my question is, AM I SETTING MYSELF UP FOR THE KILL? Do i need to just NOT show up for the appointment? I've heard some good and bad things as far as if my car will hold up to the small shot of nitrous. SOMEONE with a little knowledge in this department PLEASE help me out! THANX TO ANYONE!
Old Oct 30, 2003 | 07:13 PM
blackhatchy's Avatar
Default Re: !!!!!!!!!!!!!!!!!! ALRIGHT, PLEASE I NEED TO KNOW QUICK !!!!!!!!!!!!!1 (98BlackEX)
at least you didnt call it NOS.........
you probably want to build your engine a little before doing it, though.
slammed_93_hatch's Avatar
search is youre freind dude but you can run alot on a stock motor you just gota make sure the other elements are good, and that youre motor is in good shape, search there are some good threads about nos setups and what they use
Old Oct 30, 2003 | 07:22 PM
D16Z6racing's Avatar
Default Re: !!!!!!!!!!!!!!!!!! ALRIGHT, PLEASE I NEED TO KNOW QUICK !!!!!!!!!!!!!1 (slammed_93_hatch)
I wouldn't run anything above a 50 shot until you step up a bit.
Look up Mista Bone here on HT!
Old Oct 30, 2003 | 07:40 PM
mycivicstoo(s)low's Avatar
Default Re: !!!!!!!!!!!!!!!!!! ALRIGHT, PLEASE I NEED TO KNOW QUICK !!!!!!!!!!!!!1 (D16Z6racing)
Make your thread titles a little more low key. Damn.
Old Oct 30, 2003 | 07:42 PM
Default Re: !!!!!!!!!!!!!!!!!! ALRIGHT, PLEASE I NEED TO KNOW QUICK !!!!!!!!!!!!!1 (mycivicstoo(s)low)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mycivicstoo(s)low &raquo;</TD></TR><TR><TD CLASS="quote">Make your thread titles a little more low key. Damn.</TD></TR></TABLE>
i agree, this is why the same questions are asked over and over again.
Old Oct 30, 2003 | 08:14 PM
binkster's Avatar
Default Re: !!!!!!!!!!!!!!!!!! ALRIGHT, PLEASE I NEED TO KNOW QUICK !!!!!!!!!!!!!1 (blackhatchy)
I agree.. tone the title down a bit.. I thought your car was on fire.... but anyway... 50 shot any more with that stock and kablooy
Old Oct 31, 2003 | 04:40 AM
98BlackEX's Avatar
Default Re: !!!!!!!!!!!!!!!!!! ALRIGHT, PLEASE I NEED TO KNOW QUICK !!!!!!!!!!!!!1 (binkster)
LMAO @ "I thought your car was on fire"
You're right....didn't really notice till i posted. HA.
Thanx dood
Old Oct 31, 2003 | 04:45 AM
976's Avatar
976
New User
It is a vaild question.
I would recommend a tune-up, esp. oil change before you spray. Wait until car is completly warm...
I hope you're going to spray on the track, if not find a good strip that will not endanger anyone else. Be safe, I also do recommend a compression test before you spray.
I hope you have an aftermarket intake at least, your engine is going to need quite a bit more o2 during the combustion of n2o.
Old Oct 31, 2003 | 05:11 AM
BrotherGrim's Avatar
Don't purchase it. It's like a kid with fire, if you dont know the risk's you shouldn't be playin with matches.
Old Oct 31, 2003 | 05:16 AM
JICEK9's Avatar
Default Re: (BrotherGrim)
get a fuel pump and replace your fuel filter
Old Oct 31, 2003 | 05:54 AM
SOHC_MShue's Avatar
Default Re: (JICEK9)
don't go above a 50 shot
Old Oct 31, 2003 | 06:23 AM
Gravy's Avatar
Default Re: (SOHC_MShue)
you will be fine. i had a 75 shot on my 99 civic non vtec and it took it no problem. i didnt upgrade squat.
Old Oct 31, 2003 | 07:52 AM
baphomet's Avatar
Default Re: (Gravy)
if its in good condition (the engine) it will take even a 120 shot with the proper upgrades.
1. new plugs ngk bkr7e?s
2. FPR
3. New clutch
4. Fuel pump
5. Motor mount inserts
I would use a direct port kit, but even a single nozzle will do fine. If you spray over 50 shot don't forget to pull timing - ~ 2 degrees per 50 shot. Like everyone said do a compression test. Check you timing! Make sure it is set correctly before you do anything.
Old Oct 31, 2003 | 08:01 AM
Devine's Avatar
Default Re: (slashDEVslashNULL)
also give us more info on the kit, wet or dry? what brand? If the shop that is installing the kit is a legit shop than they should know how to properly install the nitrous kit and the precautions needed to safely run the n20.
Old Oct 31, 2003 | 08:04 AM
baphomet's Avatar
Default Re: (Devine)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devine &raquo;</TD></TR><TR><TD CLASS="quote">also give us more info on the kit, wet or dry? what brand? If the shop that is installing the kit is a legit shop than they should know how to properly install the nitrous kit and the precautions needed to safely run the n20.</TD></TR></TABLE>
Thats a big if
The7thG
Honda Civic (2001 - 2005)
Feb 4, 2007 08:05 PM
pavilionmike8
Jan 23, 2006 10:56 AM
hondatuner20
Jun 4, 2005 02:31 PM
95jeremie
Mar 18, 2004 02:19 PM
Dave01
Nov 10, 2003 03:06 PM
