CEL code 16
Old Oct 30, 2003 | 03:02 PM
cjohnson_2's Avatar
Default CEL code 16
Today my winter beater 92 civic dx had a little trouble starting. I just checked to see if it was throwing any codes and a code 16 showed up.. According to my Haynes manual its a fuel injector code.. Can someone explain this more? Is it the fuel pump? or an actual injector? BTW My car has run just fine since its trouble starting.
Old Oct 30, 2003 | 10:02 PM
BatuKing's Avatar
Default Re: CEL code 16 (cjohnson_2)
clogged injectors.. clean them out then also check the connection.. it could be a dead injector. but after you crank the motor remove the plugs on each cylinder and check for gas
93LsVx
Aug 28, 2010 09:20 AM
teg969
Mar 21, 2005 10:57 AM
EFz6er
Dec 23, 2004 06:47 PM
slywfbpsi
Jun 9, 2003 11:07 AM
