What bearings to use (did search)
I have a b16a needing rod bearings. I ordered a set of 99si rod bearings which dont seem to be correct, The 99si bearings are physically narrower so i was wondering if I am supposed to order the bearings for something else or if its ok to run it with the narrow bearings.
its a b16a that should tell you what it is anyways its a 93 integra xsi i know because I took it out of the clip myself, anyways i appreciate the help but i think i found the problem half of the bearings arent pr3 there something else and im pretty sure there for a d series since the rings they sent in the first place were for a d series.
yep that's what i thought of when i read your post in the N/A forum earlier.
prolly just gave you the wrong bearings, D16 instead of B16.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mattb16a1civic »</TD></TR><TR><TD CLASS="quote">i think i found the problem half of the bearings arent pr3 there something else and im pretty sure there for a d series since the rings they sent in the first place were for a d series.</TD></TR></TABLE>
well another thing that sucks i have rod bearings for a d series engine that they wont take back, not even for credit, sucks esp since it was there fault in the first place. maybe if a bitch and moan they will take them back. oh well at least something good happened today, my cams came in 3 days before tehy were supposed to.
the bearings are the correct color im using a factory honda manaul, what happened is that everything i ordered, they ordered for an ex instead of an si, ive taken care of everything so far just waiting on the new bearings, also that name sounds familiar, my buddy tom used to say that name, think youve helped him out before, his name is cavakillaz on here, on hybrid garage i cant remember his name.
the colors for the rods i know i had yellow green and brown for both rod and mains but i cant remember how main of each. there at work right now so i dont forget to take them to honda when i go pick up the new stuff.
