weird idling? HELP
Old Oct 30, 2003 | 11:26 AM
PTL's Avatar
PTL
Default weird idling? Safe mode? Help
On the way home today from school , my car suddenly have this weird idle when i shift to 2nd,3rd,4,5 gear. The rpm needle slow down around 3800-4000 and it bounce back a little, and it felt really hard to go pass 5000rpm. This goes to all the gears except for 1st gear. i made it home safe then check the engine.
everything look fine ,nothing loose or leak and no check engine light .
the car drove fine this moring and before . it just running rich
Anyone know what happen ? please help, Thanks
this is 96 lsvtec motor
with b16 p&p head
type R im , Ls tb
ctr piston ,ls rod
PYR p28 ecu (running rich right now)
Rc 310 injectors
still ls tranny and stock clutch
Modified by PTL at 7:02 AM 10/31/2003
Old Oct 30, 2003 | 04:06 PM
PTL's Avatar
PTL
Default Re: weird idling? HELP (PTL)
no one know?
Old Oct 30, 2003 | 04:34 PM
philafelman's Avatar
are you sayin that youre idling around 5000rpms??? how do you idle in any gear other than neutral?
Default Re: weird idling? HELP (philafelman)
you might also wanna check out your fast idle valve and idle air control.
Old Oct 30, 2003 | 04:47 PM
PTL's Avatar
PTL
do you guy think running rich could cause this too?
it felt really hard to pass 5000 rpm so i shift to 3rd but its still do the same thing through 5th gear
Old Oct 30, 2003 | 10:00 PM
PTL's Avatar
PTL
did a search and i think my car is in safe mode that why it drive like **** .
how come there no check engine light on ?
does this " Safe mode or limp mode" happen when u were driving too ?
what cause this safe mode ?
im gonna reset my ecu tomorrow to see if it work .
Old Oct 31, 2003 | 06:12 AM
sander's Avatar
2.7(p/t)
mabye one of your ecu plugs came out a little bit
and also check your check engine light bullb and see if its burnt out
-sander
Old Oct 31, 2003 | 09:43 AM
PTL's Avatar
PTL
Default Re: weird idling? HELP (sander)
i took the ecu out and put it back .
now its normal .
anyway Thanks everyone
GSR_ITR_BOIB
Apr 14, 2023 04:38 PM
MainStreamHonda
Aug 15, 2011 08:04 PM
xxi2icexx
Apr 6, 2009 09:50 PM
martyball619
Apr 27, 2008 11:58 AM
JDM_COUPE94
Apr 21, 2007 09:54 PM
