EK brakes?
Old Oct 30, 2003 | 10:23 AM
Mako_'s Avatar
Default EK brakes?
I was wondering when you change the EK brakes to GS-R brakes do you need to change the whole axle? if not.. then what do you change?..... also how much would that job cost??
thanks
Old Oct 30, 2003 | 10:26 AM
tonyxcom's Avatar
Default Re: EK brakes? (Mako_)
you dont need to change the axle.
you need the front spindles(knuckles), calipers, rotors, and probably some brake lines.
Old Oct 30, 2003 | 10:28 AM
Mako_'s Avatar
Default Re: EK brakes? (tonyXcom)
thanks alot... do you know around how much that'll be?
Old Oct 30, 2003 | 10:31 AM
tonyxcom's Avatar
Front brake setup used should be 150-200 for parts. Cheaper if you shop around or catch a good deal.
Labor... my guess is at least $200-300 from any competent shop if you are going that route. But I am sure you can find many HT members local to you that would be willing to do it for a case of beer or a date with your sister if you truely dont feel comforatable doing it yourself.
Old Oct 30, 2003 | 12:17 PM
Mako_'s Avatar
haha thanks
Old Oct 30, 2003 | 12:28 PM
99civic_exSB's Avatar
Default Re: (Mako_)
If you have an EX you only need the front calipers. The rotors are the same.
Old Oct 30, 2003 | 02:11 PM
Mr. Choi's Avatar
New User
Default Re: (99civic_exSB)
maybe im wrong but, gsr and EX brakes are the SAME. someone confirm?
Old Oct 30, 2003 | 02:18 PM
tonyxcom's Avatar
Default Re: (Mr. Choi)
wrong. the calipers are different. Integra ones are beefier.
Old Oct 30, 2003 | 02:39 PM
EL Vap133's Avatar
Default Re: (tonyXcom)
I believe the piston on the caliper is about 1mm bigger on the GSR...
powerslide360
Apr 12, 2005 06:33 AM
b Team
Aug 6, 2003 11:42 AM
rob_d16y8
May 25, 2002 09:56 PM
