I want to put a 94 LS in my 4 door EF civic. NEED HELP!!!!
Old Oct 30, 2003 | 10:01 AM
goldito187's Avatar
Default I want to put a 94 LS in my 4 door EF civic. NEED HELP!!!!
I woul like to know where the wire harness goes after in goes through the firewall. Does it go striaght to the ECU or does it also go to the instrument panel on the dash board and guage cluster. My friend has a 91 4dr civic and we have a 94 LS lying around and we would like to know if it is as hard as people say.
If you have done it before or know someone who had done it before please tell me everything I will need.
Thanks.
Old Oct 30, 2003 | 11:37 AM
Redline130's Avatar
Default Re: I want to put a 94 LS in my 4 door EF civic. NEED HELP!!!! (goldito187)
You'll need mounts, axles, a wiring conversion harness (if you are going to use an OBD1 ecu), a cable tranny, and of course tools and a manual of some sort. As for the harness, the wiring splits, some goes to the ecu, some to the gauge cluster and some to the instrument panels.
I suggest that you use this: https://honda-tech.com/zerosearch
RedEFonSIrims
12
Feb 10, 2009 02:29 PM
sik96teg
16
May 26, 2006 11:23 AM
94Acura
Sep 15, 2004 11:02 AM
NaStYeG
31
Feb 18, 2004 01:17 PM
