JDM 4.785 FD
Old Oct 30, 2003 | 08:51 AM
The Toecutter's Avatar
Default JDM 4.785 FD
This winter I'll be installing a FD in my transmssion. Is there any particular part that fails in a B-series tranny? I really do not need a grocery list of parts just ones that people have had to replace. The tranny I have has almost 90,000 miles on it and still shifts very well.
Also, I've done a search and some people specified replacing the friction damper that's not necessarily include in the FD kit. Can I use the old one in the tranny?
Thanks for all that help
Old Oct 30, 2003 | 09:04 AM
sackdz's Avatar
Default Re: JDM 4.785 FD (The Toecutter)
Since the title is perfect, I'll have to ***** your thread to announce that I will have 2 JDM FD's for sale this winter. thx.
Inspect the synchros while you're in there, but at the same time, if it aint broke dont fix it. The only thing I replaced was the top ball bearing on the cshaft cause i screwed it up when taking it out.
I reused the friction damper.
Old Oct 30, 2003 | 09:28 AM
Default Re: JDM 4.785 FD (sackdz)
How did you screw it up? Anything I need to be aware of?
Thanks
Old Oct 30, 2003 | 09:32 AM
sackdz's Avatar
I put the puller on the outside of the bearing and not the inner race and it fucked it up. I don't know how else to get it off though because the gap in between the two is so small... anyone?
Old Oct 30, 2003 | 11:38 AM
sackdz,
Are the FD's you are selling used or new?
Old Oct 30, 2003 | 01:03 PM
sackdz's Avatar
Used ring gear and cshaft 10k and 17k miles. New JDM 1st gear, distance collar and needle bearings.
Old Nov 4, 2003 | 06:01 PM
mikestypeR
Guest
Posts: n/a
yes man the third gear syncro's go in the tranny's all the time they start scratching and its not east to listen to or to feel at that my second on the R does it when i shift to second too fast and i chringe every time i hear it ....
Old Nov 4, 2003 | 06:09 PM
jdmspoonitr's Avatar
Default Re: JDM 4.785 FD (mikestypeR)
Might as well change the flywheel and clutch while you are in there if you plan on it soon. You don't need it of course, but it would save having to spend time on another pain in the *** install.
B18c5rx
Jun 7, 2005 03:32 PM
jDMJeRk
Aug 11, 2004 05:47 AM
Linh.
Mar 25, 2004 05:38 PM
johnzm
Jan 12, 2003 08:50 PM
89HF
Oct 16, 2001 05:18 PM
