Is it safe to steam clean the engine?
Old Oct 30, 2003 | 06:33 AM
Euro98ITR's Avatar
Default Is it safe to steam clean the engine?
My mom just bought a new steam cleaner.... I was going to try to clean the engine bay with it. Is it safe? especially on the red valve cover.
Old Oct 30, 2003 | 06:40 AM
Willard's Avatar
Default Re: Is it safe to steam clean the engine? (Euro98ITR)
I would just use soap and water....
if the stains persist try higher pressure water.
Old Oct 30, 2003 | 06:51 AM
Opie's Avatar
Default Re: Is it safe to steam clean the engine? (Willard)
You'll be ok just cover your distributor and battery. Then just spray away! Use caution thats all! I did that my first weekend with my car with some degreaser crap i bought @ auto zone! Went crazy with the hose no probs here
Old Oct 30, 2003 | 07:03 AM
Champ R's Avatar
Default Re: Is it safe to steam clean the engine? (opie112)
Simple Green really got out tough grime and stains on my valve cover. Definitely cover up any electrical devices in the engine bay tho when doing this.
Old Oct 30, 2003 | 09:21 AM
00JunSi's Avatar
Steam cleaning a engine bay is a bad idea because steam is extremely hot and can damage wire harnesses and other delicate parts I suggest to use a normal high pressure spray with some engine degreaser and just cover up the distributor + alternator
Old Oct 30, 2003 | 09:41 AM
DC2Slow's Avatar
for the valve cover if u want that new clean wet look spray it with some wd40 itll look great....made my stock valve cover look spankn new.
Old Oct 30, 2003 | 09:43 AM
filthyCREX's Avatar
Default Re: Is it safe to steam clean the engine? (DC2Slow)
Actually, there is a shop in my area that steam cleans engine bays. Don't know how much, but you should look around, someone might do it.
Old Oct 30, 2003 | 09:44 AM
DarthLuder's Avatar
New User
OT, the steam bug i bought was a waste of money. Leak here and there.
Old Oct 30, 2003 | 02:01 PM
Project SSAP1's Avatar
simple green and gunk own u..here are a couple of pics of when i did my own engine cleaning...it only take about 30min..more or less if u have a dirty engine bay and need to use a tooth brush..put it work and u will have a clean bay..
Old Oct 30, 2003 | 02:12 PM
Euro98ITR's Avatar
Default Re: Is it safe to steam clean the engine? (Project H22DC4)
Thanks for your advice guys. But in Malta Simple Green does not exist!
Old Nov 4, 2003 | 05:58 PM
mikestypeR
Guest
Posts: n/a
man I would have to say no ... I know it takes forever and its a pain but get a hand bucket make some soapy water and use a paint brush and go over only what you wont hurt or damage with the water then you wont have to worry about getting water into something you dont want to ... plus you can sit back and take some pride that you broke a sweat and actually worked on your car...
Old Nov 4, 2003 | 06:05 PM
AK94GSR's Avatar
Default Re: Is it safe to steam clean the engine? (mikestypeR)
Use simple green first and then some Gunk engine degreaser for the tough spots. let it sit for a bit then hose off
once its hosed down good...just spray a good dose of tire foam all over the place and let it do its thing
then just wipe down and your chit is clean as hell
Old Nov 4, 2003 | 08:54 PM
GettaluvR's Avatar
New User
Default Re: Is it safe to steam clean the engine? (AK94GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AK94GSR &raquo;</TD></TR><TR><TD CLASS="quote">once its hosed down good...just spray a good dose of tire foam all over the place and let it do its thing
then just wipe down and your chit is clean as hell</TD></TR></TABLE>
tire foam does the job for all the rubbers in engine bay ? can it take the heat ? doesn tire foam so greasy ?
Old Nov 4, 2003 | 09:00 PM
GettaluvR's Avatar
New User
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DC2Slow &raquo;</TD></TR><TR><TD CLASS="quote">for the valve cover if u want that new clean wet look spray it with some wd40 itll look great....made my stock valve cover look spankn new.</TD></TR></TABLE>
u sure wd40 will do the job ? if so i want to try it
Old Nov 4, 2003 | 10:33 PM
GRAVEDIGGER's Avatar
Default Re: Is it safe to steam clean the engine? (GettaluvR)
. by hand is the best with light soap , quick detailer and water, otherwise water will end up where it shouldnt be.wd 40 is a going to attract more dirt because it is greasy same with the armoral or the tire juice trick ..just make sure to wipe off any excessive grease and that should help.
Old Nov 5, 2003 | 09:17 AM
B U N M A N G O's Avatar
Default Re: Is it safe to steam clean the engine? (ITR GURU)
What kind of steam cleaner did your mom buy? Is it one from an infomercial? If so, I have to agree w/ ITR GURU
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR GURU &raquo;</TD></TR><TR><TD CLASS="quote">OT, the steam bug i bought was a waste of money. Leak here and there. </TD></TR></TABLE>
not only did it leak, but the steam didn't last for too long... probably 5 minutes of steam time total. Even then, all it did was push dirty water around. Steam buggy =
Old Nov 5, 2003 | 09:54 AM
itr-j's Avatar
Default Re: Is it safe to steam clean the engine? (B U N M A N G O)
Shark steamer
i saw the infomercial
is it any good?
Old Nov 5, 2003 | 12:24 PM
myhatchrips's Avatar
Default Re: Is it safe to steam clean the engine? (itr-j)
haha i seen that infomercial. almost impulsed me to buy it. but nahh
Old Nov 5, 2003 | 12:33 PM
99integralsturbo's Avatar
all simple green is is a degreaser so any degreaser will work<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Euro98ITR &raquo;</TD></TR><TR><TD CLASS="quote">Thanks for your advice guys. But in Malta Simple Green does not exist! </TD></TR></TABLE>
Old Nov 5, 2003 | 04:34 PM
mr_b401's Avatar
Default Re: Is it safe to steam clean the engine? (99integralsturbo)
1/2 simple green 1/2 water.....spray on the whole bay (be sure to cover the electrical stuff) wait a few minutes & hose off. Works every time.
Oknoe.
Apr 27, 2010 07:54 PM
mynameizstitch
Jul 3, 2009 04:15 PM
polishedturd
Mar 6, 2008 11:45 AM
gator88
Jul 18, 2006 04:59 AM
PYITR821
Jun 6, 2002 04:30 PM
