Would the Recaro Srd brackets slider fit Jdm Itr Recaros?
Like the topic states:
Would the Wedge Engineering brackets/sliders for 'USDM' Recaro Srds fit Jdm Itr Recaros (Dc2)?
Anyone know for sure, I found a killer deal on some Jdm Itr recaro but, no brackets/sliders.
Thanks
Thanks
My roommate is using the wedge brackets on the red JDM ITR Recaro's. I'd say yes.
If you want a pic bad enough, I'll take one.
yes they do. I did that exact change going from my SRD seat to a JDM Recaro on my driver's side.
Be aware, though, that the wedge combo shifts the seats a bit outward and the outside side bolster ends up touching the door armrest a bit. Not a problem, but it does touch, while the bracket I use for my passenger side (japanese aftermarket) can be perfectly centered(adjustable).
The side bolster on my seats is also touching the door armrest, but it's not much, it may be that my fat *** is stretching the seat as it's a bit tight
As I have a Euro ITR we have the same recaro's as the jdm version as standard.
I have a Greddy bracket on my passenger side seat that I purchased from jdmpassword.com. It sits a little lower than the stock JDM seat bracket and is actually sold in Japan as an aftermarket bracket to lower the driver. One of the provisions it has is a side to side adjustment for centering.
I've heard vision rails are the best for Recaros as they sit a bit lower thatn the stock JDM brackets that come in the JDM R's. I've never used vision rails so I can't comment on them.
if you like, IM me and I'll get you the address for Wedge engineering if you want to go that route.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BenB »</TD></TR><TR><TD CLASS="quote">Where did you purchase your wedge brackets from?</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=652712
you'll still need the recaro rails to bolt the seat to the bracket, though.
if you need the address and # for wedge, IM me.
just call them and ask them what they have in stock. I happened to call when the greddy bracket was on a seat that had just come in. you might get lucky.
it wasn't a listed item.
as for the vision brackets... sorry, I don't have a clue.
it wasn't a listed item.as for the vision brackets... sorry, I don't have a clue.
Mr.Fairlady
Jul 10, 2004 11:06 AM
flipsi266h
Feb 27, 2004 12:05 PM
machgo5go
Sep 26, 2001 03:48 PM
