code 43 still persists: any ideas?
Old Oct 29, 2003 | 11:05 PM
specie's Avatar
Default code 43 still persists: any ideas?
vehicle: '95 LS
I've been trying to deal with a code 43 for the longest time. It's a fuel system problem. I've replaced the 02 (3 times), the fpr, injectors, fuel filter, and now have a walbro pump. An ecu is next on the list. The problem started after I removed my air bag; might just be a coincidence.
I've noticed that after I shut off the car, the fp drops to zero w/i a couple seconds. I believe fuel pressure should stay up for a little while. My fp guage shows around 42psi when the engine is running. I have no clue what the problem might be. Anyone have pictures around the fuel filter area. I just wanted to make sure that nothing is missing that's causing the problem. Thanks.
Old Oct 31, 2003 | 10:56 AM
specie's Avatar
Default Re: code 43 still persists: any ideas? (specie)
anyone have pics near their fuel filter?
Old Oct 31, 2003 | 11:50 AM
b20turbojason's Avatar
just an idea but if you are dropping pressure think may it could be fpr. i don't know how they act when they go bad but. i have noticed that they do go pretty often.
Old Nov 1, 2003 | 11:23 AM
specie's Avatar
Default Re: code 43 still persists: any ideas? (b20turbojason)
I've changed the fpr already, but I still have the same problem.
jakem200
Apr 29, 2009 06:03 PM
thatnikkashoD
Feb 23, 2008 08:54 PM
3.point.2
Dec 16, 2006 01:12 PM
fresh99si
11
Jan 21, 2004 11:22 AM
