injector?
Old Oct 29, 2003 | 09:21 PM
noble4ws's Avatar
Default injector?
ok guys im doin an h23 to h22 swap in a prelude and i kept reading that the injectors can be swapped (ie using the same plugs) but i couldnt get mine to work so i get to lookin and on the h22 harness the injector plugs have been changed so i pulled the injector out and the only markings on it are "kei hin" on one side of the upper plastic 4 dots on the other side with 6 P D C in the center and PD28 stamped on the lower metal part, any idea what these are from and can they safely be used on an h22, obdI by the way, or do i have to change the resistor pack.
Modified by noble4ws at 1:31 AM 10/30/2003
Old Oct 30, 2003 | 06:55 AM
noble4ws's Avatar
ttt need to know
Old Oct 30, 2003 | 07:31 AM
CHK4TIX's Avatar
Default Re: (noble4ws)
this is all i can find
http://www.keihin-us.com/inje.html
Old Oct 31, 2003 | 10:52 AM
dc2h22's Avatar
Default Re: (CHK4TIX)
those are lude injectors
Old Oct 31, 2003 | 11:19 AM
noble4ws's Avatar
how do you know, the h22 harness had been spliced and they dont plug into the h23 harness, everyone says that they should
mondiex
May 28, 2012 09:55 PM
farfrumugen
Jul 2, 2010 10:44 AM
dickeytk
Aug 17, 2006 10:15 AM
Gerst240
Oct 30, 2003 11:25 AM
