Are All T3 and/or T04E Turbos the same whether they are made bu Garrett or Turbonetics?
Old Oct 29, 2003 | 06:07 PM
DigitalFusion's Avatar
Default Are All T3 and/or T04E Turbos the same whether they are made bu Garrett or Turbonetics?
Hey,
Are they the same dimensions wise? I mean i know the T3 Turbine, whether its Garrett or Turbonetics, has the same flange bolt pattern, and downpipe bolt pattern. Would I be able to bolt a Turbonetics housing and backing plate to my garrett center section?
Old Oct 30, 2003 | 05:59 AM
M.A.R.C.'s Avatar
Default Re: Are All T3 and/or T04E Turbos the same whether they are made bu Garrett or Turbonetics? (WebGeek
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WebGeek &raquo;</TD></TR><TR><TD CLASS="quote">Hey,
Are they the same dimensions wise? I mean i know the T3 Turbine, whether its Garrett or Turbonetics, has the same flange bolt pattern, and downpipe bolt pattern. Would I be able to bolt a Turbonetics housing and backing plate to my garrett center section?</TD></TR></TABLE>
it should as long as it was designed for the same trim wheel i think. my friend had a turbo just the other day... had a garrett compressor housing and a turbonetics turbine housing (both housings clearly stamped). so my guess is it should work
Old Oct 30, 2003 | 06:10 AM
VTC_CiViC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CivicRyda2k &raquo;</TD></TR><TR><TD CLASS="quote">
it should as long as it was designed for the same trim wheel i think. my friend had a turbo just the other day... had a garrett compressor housing and a turbonetics turbine housing (both housings clearly stamped). so my guess is it should work</TD></TR></TABLE>
That's my turbo. Garrett compressor, Crap-o-netics turbine.
Old Oct 30, 2003 | 10:54 AM
interesting.. thanks!
Now my next question.. are all housings created the same? I mean If i get my hands on a T04E housing, and purchase a 50 trim wheel, will it fit? Does the housing have to match the trim?
Nutzurchin
May 20, 2014 01:49 PM
D-Man
Sep 12, 2004 06:49 PM
civperc
Sep 28, 2003 05:59 PM
austrian type-R
Sep 19, 2003 08:58 AM
