Projector Headlights for a 99 Accord
Old Oct 29, 2003 | 06:02 PM
chasnjason's Avatar
Default Projector Headlights for a 99 Accord
I was just wondering if anyone could help me make a decision on some projector headlights. I have a 99 accord navy blue pearl. I've been looking on ebay and found several that I liked but do not know anything about them. Some are made by "tyc" and "jdm" I don't which one is the best. If anyone has used these or are using another brand, let me know what you think about them. Does it matter if they are halo or not, or is that just for effects. I think the halo looks better and it should give the car a different look. What I'm looking for is something that is going to give me better lighting than the stock lights. If projectors aren't that good should I go with Piaa replacement bulbs?
Modified by chasnjason at 8:04 AM 10/30/2003
Old Oct 29, 2003 | 06:05 PM
fluxion's Avatar
amin n'rangwa edanea
Default Re: Projector Headlights for a 99 Accord (chasnjason)
halo's suck ***, and i'm not to sure about the other projector lights out there. and i dont think there is a jdm projector headlight, unless it was "jdm-style" which usually just means it has a black housing. definetely stay away from the halo's though, the light output is pretty bad.
Old Oct 29, 2003 | 06:07 PM
stinker504's Avatar
I have projectors on my 01 accord. They look good, but their light output sucks. If you get them you may want to get some HID's to go with them.
Old Oct 29, 2003 | 06:12 PM
chasnjason's Avatar
Default Re: Projector Headlights for a 99 Accord (fluxion)
Is the light output comparable to the factory lights or worse. Thanks for the info, so now all I have to do is find which one I want to put on my car. The projectors that I have found range from 150-180. TYS being the most expensive. Would you look at this website and let me know what you think about these. http://search-desc.ebay.com/se...dSort
Modified by chasnjason at 3:30 AM 10/30/2003
Old Oct 29, 2003 | 06:39 PM
fluxion's Avatar
Default Re: (stinker504)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stinker504 &raquo;</TD></TR><TR><TD CLASS="quote">I have projectors on my 01 accord. They look good, but their light output sucks. If you get them you may want to get some HID's to go with them.</TD></TR></TABLE>
that would be a decent option cept the halo projectors tend to melt with hid bulbs.
of all the lights listed i'd say the get the tyc's. i havent heard anything about them but they're probably better than all the other cheap **** on there. they dont look too bad either.
Old Oct 29, 2003 | 09:10 PM
Andy4dtw's Avatar
I'd say just get a Hella or Philips HID kit on your factory headlight and call it a day. Projectors look tight but light output sucks ***. In most cases aftermarket projectors output with HID kits still suck b/c the beam pattern couldn't be aimed that well.
Old Oct 30, 2003 | 10:25 AM
-Bionic-'s Avatar
Former Sponsor
Default Re: (fluxion)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fluxion &raquo;</TD></TR><TR><TD CLASS="quote">
What makes you say this? Doesn't HID bulbs use less wattage, therefore less exotermic? Please explain.
Old Oct 30, 2003 | 10:48 AM
Meisoslow's Avatar
Default Re: (-Bionic-)
The halo projectors are cool and get a lot of attention; however, you are basically driving all the time with fog lights. The main projectors, at least the ones that are not TYC, run off of h3's which are the typical fog light bulb. TYC's run off of H!'s which are ok. The H1's are the same bulb the ludes run off of. IMO, forget the projectors. Get black frames and HID...Or the 9005 conversion for most of the cheep bastards out there like myslef...
jnohyi
Lighting
Nov 16, 2007 10:23 AM
xluben
Jan 12, 2007 12:00 AM
fluffy
Mar 14, 2005 05:38 PM
ramz7887
May 2, 2003 05:45 PM
