broken eg climate control?
i dont know if any of you have this problem too, but if so i hope there is a solution. well in a eg climate control, the part that lights up the left side(over the temperature adjuster) is extremely dim. i have replaced the bulb, but that didnt solve the problem. any suggestions?
It's probobally just the bulb. There really isnt a whole lot in it. Either the bulb on that side is gone, or the wiring to that bulb is bad. Pull the climate control out and start checking. Hell, light it up with the face off to see if the bulb is lighting up!
I read that, but did you check to make sure that the bulb is lighting up?? One side of my cluster went dim in my EK and I had a burnt out bulb.
JaeOne3345
60
Jun 19, 2003 02:47 PM
