I seriously need help on this b16a2 knock sensor thing, please!!!!!!!!!!!!!!
Old Oct 29, 2003 | 04:31 PM
hj's Avatar
hj
Default I seriously need help on this b16a2 knock sensor thing, please!!!!!!!!!!!!!!
OK to start off i have a 94 civic ex (d16z6 vtec)
Im putting a b16a2 in it and i need some help. i know the d16z6 harness has everything except for the knock sensor. cn someone tell me how to do it. i mean..
1. where is it?
2. where to run wire
3.where do i put the wire in the new ecu?
4.how do i do that?
a.do i pull the plug out of the ecu space and put the wire in the plug, cripm it down and put it back in or what?
THANK YOU SO MUCH IF YOU CAN HELP ME!!!!!!!
Old Oct 29, 2003 | 04:40 PM
poison's Avatar
Default Re: I seriously need help on this b16a2 knock sensor thing, please!!!!!!!!!!!!!! (hj)
1. located at the back of the motor near the cylinder head.
2. run the wire from the knock sensor (one wire) to the D3 pinout
3. what ECU you running with the B16A2? I would recommend using the P28 which doesn't require knock sensor wiring.
4. If you have a wire at the D3 pinout, then using an OBD1 ecu that requires knock sensor, you can just splice/solder into that wire. If you use the p28 (which I recommend and just chip it for the B16), then you don't need to do anything.
HTH.
beginmyhonda
Jul 29, 2009 02:14 PM
BILLisCHILL
May 8, 2008 06:40 PM
eskerley
Dec 4, 2007 08:18 PM
jdmdseries
Nov 16, 2007 03:46 PM
nub_pwn
Nov 18, 2006 11:48 PM
