Acura TL, RL & ZDX Includes Legend, Vigor and 2001 - 2003 Acura CL
ENGINE WON'T STAY ON, HELP!!!!!
Old Oct 29, 2003 | 03:38 PM
kamdog's Avatar
Default ENGINE WON'T STAY ON, HELP!!!!!
I have a 92 vigor, for some reason it is not staying on. I can crank it but then it just dies. When the key is in the ON position none of the lights are one, the radio is not on either. I checked the fuse but it looks OK. Any idea of what it could be. I just started today and cuts off in the middle of driving.
thanks ahead of time!!!!
Old Oct 29, 2003 | 05:29 PM
Chiovnidca's Avatar
Default Re: ENGINE WON'T STAY ON, HELP!!!!! (kamdog)
Ignition switch maybe?
Old Oct 29, 2003 | 07:55 PM
vigor5spd's Avatar
Its a common problem on the Vigor. You get no power when you turn the key in the IGN I and IGN II position. However the car starts. Since you are not getting power to the IGN II position the car does not remain running.
It happened to my Vigor. Your ignition switch is bad. Its about $80 in parts and can be fixed pretty easily.
Or you can do what I did. I used a 3 dollar relay and fix the problem. Where are you located?
If you have any other problems, alot of active Vigor owners hang out here:
http://autos.groups.yahoo.com/...dclub/
Old Dec 17, 2003 | 11:38 AM
kamdog's Avatar
Default Re: ENGINE WON'T STAY ON, HELP!!!!! (vigor5spd)
hey, thanks for the help.
Well it was the ignition harness,
I got my hands on one for $40 bucks.
replaced it and it started up great,
Thanks for the help!!!!
Siabraham1990
Apr 17, 2019 04:37 AM
kevpple
Nov 14, 2010 04:05 PM
hondabeater
Sep 7, 2009 04:00 PM
GO-FIGHT-KILL
May 22, 2007 06:34 PM
tgorman928
Acura TL, RL & ZDX
Feb 23, 2006 10:07 PM
