what did I do...?
Old Oct 29, 2003 | 03:01 PM
Gonzo_SiR's Avatar
Default what did I do...?
I was hooking up my new Proform Shift Light. Here's what I did...
1)hooked up red wire to the positive Batt. terminal
2)hooked up black wire to the negative Batt. terminal
3)hooked up the tach wire to the blue wire out of the Distributor.
4) I tried to turn on the car but it's completely DEAD.
Did I screw up my Distributor..? Any help would be appreciated.
Old Oct 29, 2003 | 03:28 PM
RCautoworks's Avatar
Default Re: what did I do...? (Gonzo_SiR)
Do any of the lights come on at all ? Does it try to crank at all ? What do you mean by dead ? If nothing happens, its the battery or a fuse. Check all the fuses and make sure none of them blew.
Old Oct 29, 2003 | 04:20 PM
Grease Monkey's Avatar
Default Re: what did I do...? (90blackcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Do any of the lights come on at all ? Does it try to crank at all ? What do you mean by dead ? If nothing happens, its the battery or a fuse. Check all the fuses and make sure none of them blew.</TD></TR></TABLE>
Old Oct 29, 2003 | 05:13 PM
Gonzo_SiR's Avatar
Default Re: what did I do...? (Grease Monkey)
it doesn't crank..... which fuses more likely, inside the car or engine bay.. good idea though i'll check'em
Old Oct 29, 2003 | 05:22 PM
Check them all.
92eg_h22
Lighting
Mar 5, 2009 11:16 AM
envision
Dec 11, 2007 03:40 PM
crdcz03
Jun 22, 2005 07:08 PM
Orangecivic251
11
Jun 16, 2004 03:33 PM
oryanh
Mar 26, 2003 02:00 PM
