How do you extend 02 sensor wire
Old Oct 29, 2003 | 02:25 PM
Del_Slowest's Avatar
Default How do you extend 02 sensor wire
I have a turbo downpipe and my o2 sensor wire is not long enought to go to the hole in the downpipe. How do i make an extension. My uncle says you don't want to cut and solder the wire b/c he says that it throws off the voltage a little and messes things up. Is this true? I have a A/F guage in the mail so i'd have to splice into the 02 wire anyways for that wouldn't i? Any help would be appriciated.
Old Oct 29, 2003 | 02:31 PM
shermanyang's Avatar
Default Re: How do you extend 02 sensor wire (Del_Slowest)
yeah what your uncle says is true. even if you solder the a/f gauge wiring...once you open that wire up...the metal hits air and starts to rot/rust/etc. i know because i have this problem and have yet to fix it. what i did to connect my harness to the O2 on my cat was make an extension using a male and female plug from a dead O2 and another wiring harness. i soldered the wires using NO CLEAN FLUX (has no acid) and used srink tubing with electrical tape to seal the bastard. then just plugged one end to the O2 and the other end to the harness. I'll take a pix of it if you really need a visual.
Old Oct 29, 2003 | 02:38 PM
Default Re: How do you extend 02 sensor wire (shermanyang)
thats what i was thinking about doing but it's so hard to find dead o2 sensors. 4 wires are so rare in the junk yards. Are there any other 4 wire plugs off a obd1 civic or obd0 honda/acura that i can use
Da_1991
Nov 10, 2013 07:14 PM
ken2830
Dec 11, 2006 01:04 PM
redflaredb1690
May 12, 2006 01:56 AM
dropd4door
Dec 27, 2004 10:22 PM
civicmatt
Jun 22, 2003 07:27 PM
