z6 head onto y8 block distributor question.
Old Oct 29, 2003 | 05:18 AM
SOHC_MShue's Avatar
Default z6 head onto y8 block distributor question.
If I have a d16y8 with an obd1 conversion and I swap a z6 head on it I know that I will need a z6 distributor with y8 distributor internals swapped into it. Would I still need to swap the internals if I have an obd1 conversion?
Old Oct 29, 2003 | 10:01 AM
rallycivic's Avatar
Default Re: z6 head onto y8 block distributor question. (SOHC_MShue)
no, a z6 distributor is already obd-1, if you had a y8 distributor you would have to swap to obd1 internals
Old Oct 29, 2003 | 07:57 PM
SOHC_MShue's Avatar
Default Re: z6 head onto y8 block distributor question. (rallycivic)
but if I had didn't have an obd1 conversion would i have to swap in the obd2 internals from the y8 dizzy into the z6 so it would fit on the z6 head? So what your saying is that if I have an obd1 conversion i can just use a z6 dizzy without y8 internals?
ef_hybrid
34
Jul 2, 2013 09:41 AM
toolbox21
Jul 21, 2008 07:29 PM
crx2ner
Jun 30, 2005 07:30 PM
hatchback_al
Sep 27, 2004 11:31 AM
project dc2
Dec 19, 2002 10:42 PM
