list your clutch and flywheel
Old Oct 29, 2003 | 01:53 AM
jeremy.'s Avatar
Default list your clutch and flywheel
looking into getting a new clutch....can you guys post your experiences with different brands...i'm looking to spend under $350
Old Oct 29, 2003 | 05:49 AM
b19coupe's Avatar
Default Re: list your clutch and flywheel (ek_jeremy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ek_jeremy &raquo;</TD></TR><TR><TD CLASS="quote">i'm looking to spend under $350</TD></TR></TABLE>
Well, that leaves my clutch out. It was $900 + tax.
Old Oct 29, 2003 | 08:42 AM
2sloCrx's Avatar
toda fly/exedy clutch
Old Oct 29, 2003 | 08:44 AM
yeer's Avatar
ACT HDSS and their prolite flywheel
Old Oct 29, 2003 | 08:46 AM
ihaterice's Avatar
Default Re: list your clutch and flywheel (yeer)
stock itr clutch and fidanza flywheel
Old Oct 29, 2003 | 08:58 AM
zigs's Avatar
Default Re: list your clutch and flywheel (ihaterice)
act prolite flywheel and exedy clutch
Old Oct 29, 2003 | 10:33 AM
snowseeker's Avatar
Default Re: list your clutch and flywheel (zigs)
Clutch masters flywheel stock clutch act pressure plate.
Old Oct 29, 2003 | 10:50 AM
junya16's Avatar
Default Re: list your clutch and flywheel (snowseeker)
comptech flywheel...act street disc and pressure plate
Old Oct 29, 2003 | 10:53 AM
quikyEG's Avatar
Default Re: list your clutch and flywheel (junya16)
clutchmaster stage 3 with clutchmaster flywheel
Old Oct 29, 2003 | 11:08 AM
slofu's Avatar
contact Rocket for an Action Clutch. they're very well made, strong and smooth. i have a 6 puck unsprung kevlar disk with a single diaphram pressure plate. even on my friend's setup, same disk, but dual diaphram (to hold high-boost power), engagement is smooth enough for street use, and it holds the power well at the track. pedal feel is firm, but won't give you leg cramps in traffic.
any of the aluminum flywheels with the replaceable friction plates are pretty good; most are made by the same company. shouldn't set you back more than $225.
also, the kevlar clutches will wear very nicely/slowly, and are less prone to burn/warp your flywheel than metal-based pads. Exedy/Daiken make the stock Honda clutch, which is decent, though if you're going to buy a new clutch, i'd upgrade, and organic material is much like that on common brake pads; kinda cheap.
at any rate, before you plan a budget and purchase, i highly recommend reading Rocket's 'Clutch 101' thread.
Tilton clutches (twin or triple disk), are great, but at &gt;$1000 are unnecessary for most of us.
Old Oct 29, 2003 | 11:24 AM
TrboInteg's Avatar
I've been abusing my Clutch Masters Stg.1 and lightweight flywheel for the past two years. I haven't had a single problem yet. I would recomend them to anyone.
mmtegra
Sep 26, 2007 08:57 PM
slow fkn hatch
Oct 19, 2004 11:32 PM
BoostedIntegra
Jan 15, 2004 07:59 AM
CDN Yellow ITR
Dec 5, 2003 12:59 PM
gotnothing
Dec 9, 2002 02:43 PM
