ATTN: VAFC owners... no, I'm not asking for settings....
Old Sep 5, 2001 | 03:33 PM
JG Luder's Avatar
Default ATTN: VAFC owners... no, I'm not asking for settings....
#1. How do you like it?
#2. Whats the general theory behind tuning it? Any special key I should look for?
Old Sep 5, 2001 | 04:14 PM
Mike95lude's Avatar
Default Re: ATTN: VAFC owners... no, I'm not asking for settings.... (JG Luder)
Well my V-AFC is still in its packaging unused but...what you should do when dyno tuning it is figure out the optimal cross-over for your cams...since you have aftermarket custom cams this is especially critical....you want to figure out the exact point at which your VTEC lobe starts making more power than your non-VTEC lobe....so set VTEC to kickin at say 3500, do a dyno run.....then set it to kick in at like 6500 or something, do another run...you should set VTEC to then engage where the two graphs intersect...meaning at the most powerful point on your non-VTEC lobe
There is more to it like tuning the fuel% and throttal positioning, but I don't know much about that so I'll leave it to someone else.
[Modified by Mike95lude, 5:15 PM 9/5/2001]
Old Sep 5, 2001 | 04:15 PM
JG Luder's Avatar
Default Re: ATTN: VAFC owners... no, I'm not asking for settings.... (Mike95lude)
man, to hell with VTEC points. lol, I mean FUEL settings! I only have two or three dyno runs to get my winning dyno run.
Old Sep 5, 2001 | 04:18 PM
Mike95lude's Avatar
won't be a "winning dyno run" without the optimal VTEC x-over
Old Sep 5, 2001 | 04:28 PM
JG Luder's Avatar
YES I WILL! I'll leave it at 5k, then drop it to 4.5... i have two days to do it with. I hope I can get this thing set up close...
Old Sep 6, 2001 | 12:13 PM
bullet9925's Avatar
New User
i like mine! vtec enguaging quicker is better at least i think so. i have never dynoed my car but hope to soon
Old Sep 6, 2001 | 12:21 PM
4doorH22's Avatar
Default Re: ATTN: VAFC owners... no, I'm not asking for settings.... (bullet9925)
Errr don't you just use it to get your a/f ratio as close to 13 as possible across the board?
Using the VAFC to adjust VTEC engagment point leaves you with less than optimal fuel and ignition timing and is not recommended by those who know.
Old Sep 6, 2001 | 01:51 PM
JG Luder's Avatar
Default Re: ATTN: VAFC owners... no, I'm not asking for settings.... (Jonesy69)
I already do that, I'm hoping to FIX it.
94vtecmn
Apr 23, 2004 05:30 AM
The Poopsmith
May 26, 2003 09:16 AM
slowazzhatch
19
Jan 20, 2003 11:34 PM
gamby
Jan 13, 2002 05:15 PM
