Loose Steering
Old Oct 28, 2003 | 10:33 PM
sir91's Avatar
Default Loose Steering
My steering feels loose on my car? Can I get some ideas as to what is going on? The suspension of the car is a follows:
I have had a wheel alignment(didn't fix problem)
Tokico 5-way adjustable all around with eibach springs 1.5 drop.
JDM CRX front spindles.
90-93 Teg Axles.
Complete Prothane Kit Installed.
Place racing mounts with LS/Vtec motor
Thanks in advance for any answer.
Old Oct 28, 2003 | 11:56 PM
Jdm_Rice_Monster's Avatar
Default Re: Loose Steering (sir91)
Take it where the alignment was done that should have told you why its loose. My guess is inner tie rods or bad hub bearings. Or maybe even brakes. I have had my run in with all these on every crx I have ever owned.
Old Oct 29, 2003 | 03:43 AM
1st-hybrid's Avatar
It could be your tie rod ends, or it could be your ball joint's, or it could be you steering rack going.
Let's just say when my stearing was going bad I replaced all of them.
Old Oct 29, 2003 | 09:57 PM
sir91's Avatar
Default Re: Loose Steering (1st-hybrid)
Thanks for the advice.
Old Oct 29, 2003 | 10:17 PM
Banned Poser
Guest
Posts: n/a
I'D REPLACE THE RACK.
ef's are old and the racks need to be replaced on most of them. the difference is night and day after replacing it. feels like a whole new car.
Old Oct 30, 2003 | 12:22 AM
Default Re: Loose Steering (Pepperoni Nipples)
Yeah your best bet would be do the labor yourself if at all possible and replace everything in the front end.
Old Oct 30, 2003 | 03:43 AM
Home Skillet's Avatar
I had loose steering, this was one of my problems https://honda-tech.com/zerothread?id=527478
The other problem were that my upper ball joints needed replacing.
Old Oct 30, 2003 | 07:34 AM
1st-hybrid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Pepperoni Nipples &raquo;</TD></TR><TR><TD CLASS="quote">I'D REPLACE THE RACK.
ef's are old and the racks need to be replaced on most of them. the difference is night and day after replacing it. feels like a whole new car.</TD></TR></TABLE>
True ef's are old, but racks are expensive, unless you have the 200 plus to throw down on something that might not be the problem.
Start with a visual inspection to avoid homskillets problem .
Then if you don't see anything start with the small cheap stuff, and go from there. It's all pretty easy, and can all be done by yourself, although an extra set of hands helps.
Old Oct 31, 2003 | 09:43 AM
sir91's Avatar
I will satrt will all the small stuff all you guys have adviced. I did check for a crack in the subframe but saw nothing. I will however double check it. Thanks for all the heads up on this matter.
steronz
20
Mar 31, 2008 07:02 AM
Rywire
Mar 27, 2008 08:01 AM
Rob.
Sep 21, 2005 10:49 AM
S.Celia
Dec 8, 2003 04:46 PM
Padronis
Jul 28, 2003 09:00 PM
