H22a- Milling head to raise compresion?
Old Oct 28, 2003 | 09:15 PM
LudeHatchH22a's Avatar
Default H22a- Milling head to raise compresion?
Ok, basiccally i need as much info as i can get on this.
Is it safe? well, how much is safe?
how much difference will it make i.e. .020 will make x.1 compression?
how much will i need to adjust timing for the milling.
ive heard its safe, but you have to adjust the timing belt for some reason
lil help, knowledge appreicated
Old Oct 28, 2003 | 09:23 PM
well i already have that...i never acctually tested it, but its supposed to raise it like 2-4 tenths of a compresion. im looking to run near 12:1
Old Oct 28, 2003 | 11:44 PM
Broken Gearbox's Avatar
Default Re: H22a- Milling head to raise compresion? (LudeHatchH22a)
I thought when you mill your head you adjust the timing on the dist.?
Old Oct 28, 2003 | 11:58 PM
jarel's Avatar
Default Re: (LudeHatchH22a)
Once you mill the head....you can never put it back to normal. Maybe higher compression pistons?
Old Oct 29, 2003 | 05:21 AM
machine4321's Avatar
with cam gears you can..........
just a matter of how much..not sure if theres a way to tell
Old Oct 29, 2003 | 07:55 PM
ranta18's Avatar
Default Re: (machine4321)
This has been covered in old threads, but for every 0.012 the head is milled, it is 1 degree of retard on the cam gears.
There is a compression calculator here: http://www.c-speedracing.com/h...c.php You need to know a lot of info on the H22 though. I have my head milled 0.020 with 11:1 Type-S pistons and it figured my compression to be around 11.5:1.
Old Oct 30, 2003 | 03:36 AM
Default Re: (ranta18)
that sucks, i guess ill just get the type 2 pistons then and not mill the head.
i wanted with the type s pistons to run a comp of around 12 but to do that id have to mill the head entirely too much to be safe i guess.
thanks
Old Nov 1, 2003 | 06:30 AM
ranta18's Avatar
By that calculator, if you mill it 0.030 with Type-S pistons, you'll have 11.9:1. 0.030 is a pretty common mill. I wouldn't go too much over that, but I'v heard of guys going to almost 0.100.
When calcualting the compression for the milled head I took the volume of the combustion chamber and then recalculated it for the difference in height because of the mill. V = pi * r^2 * h I figured it was a more accurate way than just changing the head gasket thickness.
Old Nov 2, 2003 | 04:22 PM
1700anddroping's Avatar
why not just take the center layer out and raise it that way,then if you want more mill it.for every 15 ths you take off a head retard the timing 2 1/2 to 3 degrees.
Old Nov 3, 2003 | 01:34 PM
kwik93si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ranta18 &raquo;</TD></TR><TR><TD CLASS="quote"> I have my head milled 0.020 with 11:1 Type-S pistons and it figured my compression to be around 11.5:1.</TD></TR></TABLE>
that is the same amount that i milled my head w/ stock pistons, and this is exactly what i've heard...0.020 milled head = .5 raise in compression.
Old Nov 3, 2003 | 02:08 PM
RS_H22's Avatar
Default Re: (kwik93si)
H22
Type S pistons (Std. Bore)
Mugen/Spoon Head Gasket
Milled .020
11.9:1
H22
Welded Chambers
Milled .020
12.2:1
Modified by RS_H22 at 5:32 PM 11/6/2003
Old Nov 6, 2003 | 08:22 AM
welded cumbustion chamber? whats up with that? any pics?
Old Nov 6, 2003 | 08:32 AM
RS_H22's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeHatchH22a &raquo;</TD></TR><TR><TD CLASS="quote">welded cumbustion chamber? whats up with that? any pics?</TD></TR></TABLE>
no pics, you just weld some of the areas shut in the combustion chamber... Top/Bottom edge, the sides between the intake and exhaust valves... Cloverleafing is a good example of chamber welding/reshaping... Alot of people reshape the combustion chamber into a clover leaf shape to minumize the cc count which raises compression and some say to increas air flow charactoristics...
Modified by RS_H22 at 5:54 PM 11/6/2003
Mydogisgone
Mar 19, 2007 08:24 PM
fastsohc
Sep 28, 2004 09:50 PM
95GSRTT
Sep 11, 2004 09:40 AM
blackeg
10
Sep 1, 2003 08:54 AM
tinkerbell
Oct 20, 2002 09:52 AM
