junkyard turbo crvtec crx
is it worth it to make a crv vtec(b17 head) if i leave the internals stock?
i am also wondering what kind of numbers a stock crv vtec with a junkyard turbo(w/low boost 6-8psi) would have? and is it even worth it?
all of this would be going into my 88 crx si.
i have a choice of two traniess y1 w/lsd or ys1 no lsd and grinds third.
just looking for some opinons. thanks curt
I'd clay it fist. Thoes valves will probably colide without grinding the valve reliefs.
http://www.c-speedracing.com/h...y.php
it is definitely worth the mad torque. It depends on what B20 you put in as far as the valve clearance. I loved mine even before I built up the block. Definitely put the $300-400 into a fluidyne radiator though, u need the extra cooling. I blew a head gasket after a coolant line blew on the stock block and radiator.
that's what i'm running right now. b20z bottomend, with a ITR head(using gsr valve train and cams). dynoed at 180whp and 142ft/lbs of torque with i/e and chipped ecu!
moesrex
Feb 23, 2006 10:16 AM
sykotic
Apr 11, 2003 05:04 PM
