swappin ls motor into an ek need some help!
Old Oct 28, 2003 | 05:29 PM
1hotintegra's Avatar
Default swappin ls motor into an ek need some help!
first off anyone know what mounts to use when swapin a 5sp ls into a 98 ek... then im goin to use 94-00 integra and 99-up si shift linkage thats correct right... then what parts of the shift linkage am i goin to need from here http://www.acuraautomotivepart...gry5= under shift lever
any other insight will be very helpfull
Old Oct 28, 2003 | 06:48 PM
FastEK9's Avatar
u will need a 1. 99-00 civic SI rear bracket,
2.your current top tranny mount
3. if u wanna keep your A/C then either a 99-00SI ac bracket or DOHC del sol bracket.i fno ac then any 94+ B series mount.
4. 99-00 SI timing belt mount the lower one that bolts up to the block with the 3 14mm bolt is actually the only u need. the top mount that connects to that can be used off ur stock motor.
5. any B series lower tranny mount 94+
that should pretty much be it for mounts.
Old Oct 28, 2003 | 08:11 PM
That Dood's Avatar
Default Re: swappin ls motor into an ek need some help! (1hotintegra)
youll need si linkage...gsr is wither to short or too long. For mounts..Si rear, any b-series front tranny, and I think yuo have to use b-series upper tranny mount. Like the other guy said about the ac mount is right and I think for the top driver side mount you have to use si also...I dont think the stock one will work. I dont remember, but when I did mine I dont think those mounts where the same.
Old Oct 28, 2003 | 08:38 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
Default Re: swappin ls motor into an ek need some help! (That Dood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by That Dood &raquo;</TD></TR><TR><TD CLASS="quote">youll need si linkage...gsr is wither to short or too long.</TD></TR></TABLE>
gsr and si linkage are the same. maybe your thinking of a del sol bseries linkage which is too long.
Old Oct 28, 2003 | 10:25 PM
97hb's Avatar
Default Re: swappin ls motor into an ek need some help! (bruceleeroy)
All b series shift linkage should work, besides cable. Also for the ac mount get a p54 delsol vtec bracket. The 99 si bracket does not work. Switch pin a10 and a12 on the ecu side. Eliminate the orange wire from the iacv. IAT also needs to be rewired. Might be one or two more but can't think of it right now.
Old Oct 29, 2003 | 01:21 PM
That Dood's Avatar
Default Re: swappin ls motor into an ek need some help! (97hb)
I have some linkage I pulled off a GSR and I had some that I thought were from a Si motor I had...and 1 is longer than the other. Also the si will work. How do u think they put a b-series into the 99-00 Coupe. the EK engine bay is the EXACT same mount wise.
dafuzzbudd
May 13, 2009 11:18 AM
dc2sick
Dec 15, 2005 07:55 AM
CallmeLuke
Nov 28, 2003 10:12 PM
1hotintegra
Oct 28, 2003 05:51 PM
black-hatch
Apr 21, 2003 09:08 AM
