b-pipe....which ones fit??
Old Oct 28, 2003 | 04:39 PM
EKRacer's Avatar
Default b-pipe....which ones fit??
I need to know which OEM b-pipes will bolt up to my 97 hatch. I know any 96-00 hatch will fit. but what about the coupes? I know the ex won't fit because of the cat position on the y8, but what about the HX?
I ordered a Spoon N1 and I can't seem to find an exhaust flange and I'd rather have the whole b-pipe (Previous owner replaced the muffler and the shop welded up my flange location). If anybody has a b-pipe or even just a flange, I'd be will to buy it if it's cheap enough.
And yes, I checked local muffler shops and they don't have flanges.
Old Oct 28, 2003 | 04:51 PM
dantastic's Avatar
Default Re: b-pipe....which ones fit?? (EKRacer)
you could just find a cheap b-pipe and cut the flange of and weld it on
Old Oct 28, 2003 | 05:00 PM
EKRacer's Avatar
If I could find a whole b-pipe I wouldn't have to get it welded on (I don't know how to weld). There's only one 96-00 civic in the junkyard, and I've been asking around locally with no luck. I don't want to spend too much money, so it will either go to buying a b-pipe, or buying a flange + the cost of welding it on.
Old Oct 28, 2003 | 05:03 PM
nbn22385's Avatar
http://www.streetbeatcustoms.com/inpipforcatb.html
Old Oct 28, 2003 | 11:04 PM
EKRacer's Avatar
Default Re: (nbn22385)
I can't afford an aftermarket b-pipe. Thanks anyway though
Old Oct 28, 2003 | 11:07 PM
BI8B's Avatar
Default Re: (EKRacer)
how much money you got to spend on a b-pipe? just get a stock muffler.
ANDREW D
Sep 13, 2009 03:05 PM
ChainbreakR
Welding / Fabrication
18
May 25, 2007 12:55 PM
calisolekidd
Feb 12, 2007 10:28 PM
YoungKadafi
Oct 9, 2006 01:44 PM
shutta
Jun 28, 2006 04:05 PM
