Any benefits to advancing timing to 18 degrees ??
Old Oct 28, 2003 | 03:57 PM
TypeRuz's Avatar
Default Any benefits to advancing timing to 18 degrees ??
i was told i would get better low/mid power and maybe a bit better MPG.
since i drive mostly highway (with the rpms in the 4000-4500 range) i figured this may help a bit.
i was also told it will lose a little high-end in compensation.
any ideas?
any drawbacks?
btw, completely stock.
Old Oct 28, 2003 | 05:01 PM
MAD ITR 55's Avatar
Default Re: Any benefits to advancing timing to 18 degrees ?? (TypeRuz)
i adjusted mine to 18 degrees and I can't tell a difference
Old Oct 28, 2003 | 05:06 PM
jond's Avatar
There used to be dynos of it. I think its 2-3 whp. About the same as an intake.
Edit. 5whp here:
https://honda-tech.com/zerothread?id=531423
Old Oct 28, 2003 | 05:25 PM
Jowee's Avatar
Default Re: Any benefits to advancing timing to 18 degrees ?? (jond)
How exactly do you adjust it to 18 degrees?
Old Oct 28, 2003 | 05:57 PM
cjames235's Avatar
Default Re: Any benefits to advancing timing to 18 degrees ?? (ITR 98 1162)
i have dynos but i cant post them cus they are in dynojet runviewer format. dont know how to convert it over. but mine went from 157 to 164 atw just from doin this!
edit: gained all through the powerband too. not one place was it equal to or lower.
Old Oct 28, 2003 | 07:27 PM
fuck honda-tech's Avatar
Default Re: Any benefits to advancing timing to 18 degrees ?? (cjames235)
have mine done on my gizzer you can tell a difference a lil on the butt dyno
Old Oct 28, 2003 | 07:39 PM
t's Avatar
t
14-18 degrees is stock timing.
Old Oct 28, 2003 | 07:40 PM
itralex's Avatar
Default Re: Any benefits to advancing timing to 18 degrees ?? (t)
so advancing the timing on stock cams would net somewhere around 2-3whp?
Old Oct 28, 2003 | 07:56 PM
MissMyHonda's Avatar
We're talking about igintion (sp?) timing....I go w/ 16 deg. on the distrib and 1.5 advance from the ECU around town, and 22 deg. total @ the track w/ 100 oct. BIG GAINS noticed there....
Old Oct 28, 2003 | 09:27 PM
92TypeR's Avatar
FSAE
Default Re: (JoesTypeS)
The higher the timing, the greater the midrange, the lower the timing, the more top end power you'll gain...to a certain degree though. Going below 12ish will start dropping power throughout the rpm band.
Here is a dyno chart of my car 17deg timing (blue) vs 16deg timing (red). Had a run left, decided to play around a little
There is a nice 3-4wtq gain in the midrang with the advanced timing. But as you can see, it drops about 1whp up top. I left it at 17
Old Oct 28, 2003 | 11:48 PM
HYREV2NR's Avatar
I have mine @ 18 & I could tell a diff. I would suggest getting some cooler plugs to help stop detonation. NGK standard core plugs. Stock # 1273. They are 1 stage cooler than stock. Doing this I noticed a decent amount bottom to mid increase. & I didn't seem to lose any power in the high RPM's.
Old Oct 29, 2003 | 03:48 AM
jond's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR 98 1162 &raquo;</TD></TR><TR><TD CLASS="quote">How exactly do you adjust it to 18 degrees?</TD></TR></TABLE>
http://www.c-speedracing.com/h...g.php
Can someone explain if the service connector really needs to be jumped? Is this whats usually considered resetting the ECU?
Old Oct 29, 2003 | 04:09 AM
Doctor CorteZ's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jond &raquo;</TD></TR><TR><TD CLASS="quote">
Can someone explain if the service connector really needs to be jumped?</TD></TR></TABLE>
if you're **** you can jump the service connector , it keeps the ecu from changing the idle based on load variations and such.
I jump the connector everytime.
Old Oct 29, 2003 | 04:12 AM
ZygSpeed's Avatar
Yes, the service connector needs to be jumped in order for the ECU to understand that the timing is to be accepted and reset in the ECU (otherwise I believe it compensates somehow even though the distributor has been moved).
Resetting the ECU is done by either pulling the ECU fuse in the engine compartment or disconnecting the battery (if disconnecting the battery have your radio code handy).
Old Oct 29, 2003 | 04:23 AM
DutchITR1689's Avatar
Default Re: Any benefits to advancing timing to 18 degrees ?? (zygspeed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by zygspeed &raquo;</TD></TR><TR><TD CLASS="quote">Yes, the service connector needs to be jumped in order for the ECU to understand that the timing is to be accepted and reset in the ECU (otherwise I believe it compensates somehow even though the distributor has been moved).
Jumping the connector is needed to temp. disable the ECU timing compensation AT the moment you are reading the timing so you'll get an accurate reading. It's not for telling the ECU to understand the change.
In fact you don't have to short the connector if you know exactly how much you have to turn the distributor for 18 deg.
Old Oct 29, 2003 | 04:25 AM
ZygSpeed's Avatar
Default Re: Any benefits to advancing timing to 18 degrees ?? (DutchITR1689)
OK ... that's why I usually let someone else (who knows what he's doing) do the actual work on my car!
I stand corrected. Ed
Modified by zygspeed at 8:41 AM 10/29/2003
Old Oct 29, 2003 | 07:30 AM
98ITR#0020's Avatar
I advanced mine and definately noticed a difference. Mine is at about 22 degrees on pump gas, no pinging here
Old Oct 29, 2003 | 07:41 AM
jond's Avatar
Default Re: Any benefits to advancing timing to 18 degrees ?? (98ITR#0020)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ITR#0020 &raquo;</TD></TR><TR><TD CLASS="quote">I advanced mine and definately noticed a difference. Mine is at about 22 degrees on pump gas, no pinging here </TD></TR></TABLE>
1. How do you know its not pinging? Can you hear it ping at 8000+rpm?
2. Is their any HP gain after 18 degrees?
Old Oct 29, 2003 | 08:30 AM
92TypeR's Avatar
FSAE
I think after 18-19 you start dropping power significantly. Especially up top.
Old Oct 29, 2003 | 04:37 PM
t's Avatar
t
1. It will show on the dyno. Probably cant hear it from 5500RPM on.
2. Yes. Like I posted earlier 18 degrees is stock timing (and intended for the lowest octane gas that one would put in the car which is 87; I believe)
Old Oct 29, 2003 | 04:53 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98ITR#0020 &raquo;</TD></TR><TR><TD CLASS="quote">I advanced mine and definately noticed a difference. </TD></TR></TABLE>
this is called placebo.
Old Oct 29, 2003 | 05:53 PM
TypeRuz's Avatar
Default Re: Any benefits to advancing timing to 18 degrees ?? (Doctor CorteZ)
After jumping the service connector and changing the timing to where i want it...
should i reset my ECU?
Old Oct 29, 2003 | 06:10 PM
92TypeR's Avatar
FSAE
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t &raquo;</TD></TR><TR><TD CLASS="quote">
2. Yes. Like I posted earlier 18 degrees is stock timing (and intended for the lowest octane gas that one would put in the car which is 87; I believe)</TD></TR></TABLE>
I was always under the impression stock timing on a C5 is 16deg...no? Otherwise, "advancing timing" to 18deg wouldn't really be advancing would it?
Old Oct 29, 2003 | 06:30 PM
voofee's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DutchITR1689 &raquo;</TD></TR><TR><TD CLASS="quote">
In fact you don't have to short the connector if you know exactly how much you have to turn the distributor for 18 deg.</TD></TR></TABLE>
my mechanic did mine without jumping the service connector, he did use a timing gun though. and u can definitely feel the difference through the whole power band.
Old Oct 29, 2003 | 06:32 PM
t's Avatar
t
Default Re: Any benefits to advancing timing to 18 degrees ?? (92TypeR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92TypeR &raquo;</TD></TR><TR><TD CLASS="quote">
I was always under the impression stock timing on a C5 is 16deg...no? Otherwise, "advancing timing" to 18deg wouldn't really be advancing would it?</TD></TR></TABLE>
Check your underhood sticker it says 16 +/- 2, which means 14-18 is stock timing.
