Cruise control prob checklist
Old Oct 28, 2003 | 02:51 PM
ScubaStevo80's Avatar
Default Cruise control prob checklist
Can someone post a checklist of things I should check. My light comes on when I push it on the dash, but when I press the buttons on the steering wheel nothing happens. I am going to check my fuse under the dash. I also checked all the lines that run from the cruise control to the the intake manifold and they seem fine. Any other suggestions? I did a search but didn't find anything that helped.
Old Oct 29, 2003 | 02:40 AM
Default Re: Cruise control prob checklist (VolpeOwnsU)
Anyone? I need to fix this by Sunday when I sell the car. I would appreciate any help anyone can give me.
Old Oct 29, 2003 | 10:32 AM
pro1342's Avatar
Could be the brake light switch.....if it is bad, the cruise control thinks you have the brake pedal pushed in, which disengages the cruise.
Old Oct 29, 2003 | 04:02 PM
Default Re: (pro1342)
How do I check that? Check the connection on the plug?
Old Nov 1, 2003 | 12:06 PM
Default Re: (VolpeOwnsU)
Since no one responded, I figured out the answer myself. Both lights were coming on and the fuses were fine. What happened was I took off the hose that runs in between the intake manifold and the vacuum tank and installed it backwards. The little filter thingie between it only opens one way and thus wasn't letting air through. You can test this piece by blowing into one end of the tube and seeing if air comes out the other way. The end that the air comes out goes to the intake manifold. If you blow and no air comes out, you have it backwards. Just in case anyone is installing cruise into their cars, don't forget to check for this
Myechtatel
16
Jan 22, 2014 06:00 AM
obuhmyuh
Jun 7, 2008 06:43 PM
whatan00b
Aug 1, 2007 08:10 AM
slickrc
Jul 9, 2003 02:53 PM
