Engine Assembly Lube
Old Oct 28, 2003 | 01:10 PM
eghonda's Avatar
Default Engine Assembly Lube
i heard that white lithium grease is an acceptable lube for assembling my motor(bearings, cams, etc.).
can anybody confirm this? if not i'll just get some redline...
Old Oct 28, 2003 | 01:40 PM
Arturbo's Avatar
Better than steak
25 Year Member
Default Re: Engine Assembly Lube (eghonda)
I use this stuff:
Old Oct 28, 2003 | 01:50 PM
mmuller's Avatar
Mad Scientist
Default Re: Engine Assembly Lube (Arturbo)
I use the same thing arturbo sayd, and for mains and rods i use oil
Old Oct 28, 2003 | 02:08 PM
ScottEK's Avatar
Default Re: Engine Assembly Lube (mmuller)
I bought a tube of ARP assembly lube, think it was $6.00
Old Oct 28, 2003 | 02:11 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
i use that same crap
Old Oct 28, 2003 | 02:44 PM
mattb16a1civic's Avatar
i was given prolong engine assembly lube by a buddy to try out, im kinda skeptical about trying anything prolong so if anyone has any advice or experience please fill me in. At least its thick
Old Oct 28, 2003 | 05:46 PM
turbotypeR@SPEC's Avatar
25 Year Member
i like vht assembly lube.comes in a small aresol can and works great
Old Oct 28, 2003 | 07:20 PM
nevin's Avatar
I use a tub of KY, for assembely that is.
Old Oct 29, 2003 | 01:45 PM
99integralsturbo's Avatar
Default Re: (nevin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nevin &raquo;</TD></TR><TR><TD CLASS="quote">I use a tub of KY, for assembely that is.</TD></TR></TABLE>
lol
Old Oct 29, 2003 | 01:58 PM
IN VTEC's Avatar
Default Re: Engine Assembly Lube (turbotypeR)
I've started using a mix of the green Fed-Mogul stuff, the red clevite stuff, and ARP moly. Nice and thick stuff. Mix in a bowl and apply with fingers. No brush, b/c the bristles might come off or break off into the engine. And, don't clog up the oil feed holes with assy lube.
A former Lingenfelter engine builder gave us that recipe.
Old Oct 30, 2003 | 01:27 PM
still no one that has heard anything about the prolong assy lube.... still really skeptical.
Old Nov 4, 2003 | 04:37 AM
1700anddroping's Avatar
Default Re: (mattb16a1civic)
use redline or just reg.motor oil.it is for initial start up only,and sense your motor uses oil there is no harm done.
Old Nov 4, 2003 | 12:26 PM
NA EJ1's Avatar
Default Re: (1700anddroping)
this always works
j/k-ARP lube does the job just fine, you can order a pretty big jar from Summit or Jegs
Old Nov 4, 2003 | 02:16 PM
maxxdout's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eghonda &raquo;</TD></TR><TR><TD CLASS="quote">i heard that white lithium grease is an acceptable lube for assembling my motor(bearings, cams, etc.).
can anybody confirm this? if not i'll just get some redline...</TD></TR></TABLE>
Do NOT use with lithium based grease or lubes. Whiter Lithium doesnt breakdown in an oil circuit. The breakdown temp is well above the opperating temperature of our engines oil systems and will clog oil gallies, passages, and the pickup screen. The assembly lubes as mentioned earlier would be your best bet.
Old Nov 4, 2003 | 05:58 PM
martini's Avatar
I use Redline assembly lube.
I used to use that CRC stuff in a tube. But I stopped in favor of the Redline junk.
Old Nov 4, 2003 | 08:32 PM
3rdGteg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">I use this stuff:
</TD></TR></TABLE>Where to get this? (Pep Boys or Autozone or where??) price?
Old Nov 5, 2003 | 06:26 AM
non-VTEC's Avatar
Arturbo: can you use that stuff on ARP rod bolts?
Old Nov 5, 2003 | 07:42 AM
Fkned's Avatar
Default Re: Engine Assembly Lube (maxxdout)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxxdout &raquo;</TD></TR><TR><TD CLASS="quote">
Do NOT use with lithium based grease or lubes. Whiter Lithium doesnt breakdown in an oil circuit. The breakdown temp is well above the opperating temperature of our engines oil systems and will clog oil gallies, passages, and the pickup screen. The assembly lubes as mentioned earlier would be your best bet.</TD></TR></TABLE>Couldn't have said it better.Lithium = death.it will clog your filter and never leave.I've used a combination of 50w and LUCAS oil stabilizer and it works very well,even when taking apart heads that have set on the shelf for months the lube is in the guides like the day I assembled them.Oh and moly for all bolts that dont go into water.
Old Nov 5, 2003 | 11:01 AM
BigMoose's Avatar
Default Re: Engine Assembly Lube (IN VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IN VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I've started using a mix of the green Fed-Mogul stuff, the red clevite stuff, and ARP moly.</TD></TR></TABLE>
Can you tell us more? As in define:
green Fed-Mogul stuff? pix or part no?
red clevite stuff? ditto?
ARP moly..........ok.
Thanks!
Old Nov 5, 2003 | 01:45 PM
AzG35's Avatar
Default Re: Engine Assembly Lube (BigMoose)
I used Clevite 77 BearingGard for my assembly of the bottom end, ARP moly for cams and bolts.
Old Nov 5, 2003 | 01:54 PM
Bailhatch's Avatar
Default Re: Engine Assembly Lube (AzSi22)
Redline assembly lube too
Old Jul 26, 2008 | 06:41 AM
93Civic_hb's Avatar
Default Re: Engine Assembly Lube (Bailhatch)
Does anyone use some graphite compound for the rod bolts? I have seen this but no sure what is preferred.
I will be starting my first bottom-end build and need to get all the lube for a complete job. Recommendations, including there intended application?
Old Jul 31, 2008 | 04:41 PM
imptricer's Avatar
Default Re: Engine Assembly Lube (93Civic_hb)
i always use torqo or royal purple asembly lube its so sticky it says in the bearing long enough for oil to get there ! dont be scared when you go to turn the engine over it will be tough no matter what the stuff is just super sticky its just doing its job my friend thats has 555 with 1400 hp there machanics thats all they use and i always just use arp moly lube for bolts
Old Aug 13, 2008 | 01:21 PM
93Civic_hb's Avatar
Default Re: Engine Assembly Lube (imptricer)
Has anyone used or can recommend torco MPZ assembly lube?
Old Aug 13, 2008 | 03:48 PM
imptricer's Avatar
ya good stuff
