clicking help..
Old Oct 28, 2003 | 01:07 PM
binkster's Avatar
Default clicking help..
Lately my car has been making a clicking noise when I drive slowley.. If I romp on it the ticking goes away, I just had the oil changed.. Is it time for a valve adjustment?
Old Oct 29, 2003 | 06:26 AM
binkster's Avatar
Default Re: clicking help.. (binkster)
No body huh?
Old Oct 29, 2003 | 06:30 AM
CNY Hatch's Avatar
was the oil really light weight?
Old Oct 29, 2003 | 06:33 AM
JDMvtecDRAGSTA's Avatar
could be the cv joint
you should check it to see if theres any rips on it
Old Oct 29, 2003 | 06:36 AM
binkster's Avatar
Default Re: clicking help.. (Mr. Sparkle)
Just had the CV joints replaced.... Yea the oil is I live in FL ..... Dont have to worry about it getting to cold...
Old Oct 29, 2003 | 07:35 AM
Rob!'s Avatar
why dont u tell us where its coming from? engine internally? chassis? wheel area? that might help us determine what it could be.
Old Oct 29, 2003 | 07:47 AM
SloCivicHMM's Avatar
Default Re: clicking help.. (EKsnatch)
NIICE avatar...hehe...
Yeah more into too many possibilities...
Old Oct 29, 2003 | 03:45 PM
binkster's Avatar
Default Re: clicking help.. (EKsnatchback)
Pretty sure the noise is comming from the engine... Its only when Im excellerating slow at slow speeds... Sounds like valves but its not as loud as my valves have been in the past
Old Oct 30, 2003 | 06:45 AM
binkster's Avatar
yea the noise is only happening when im moving.. if i slowly rev the engine no noise and when I coast in nutral, no noise.. just when im accelerating. CV joint?
Old Oct 30, 2003 | 07:27 AM
yep
Old Oct 30, 2003 | 07:52 AM
SLOAZZ95's Avatar
If it was the cv joint then wouldnt it still do it when u were coastin in neutral, i mean the axle is still moving so it should still click, jmho.
Old Oct 30, 2003 | 08:53 AM
eG_6ix's Avatar
Default Re: clicking help.. (SLOAZZ94)
is it ticking or popping...does it "pop'' while you are turning?...if it is only a ticking you might just need to clean your fuel injectors
Old Oct 30, 2003 | 09:50 AM
-Trinitron-'s Avatar
I am sure you are going to eDiagnose a car trying to decide if it is clicking or popping. Most would consider that almost the same sound anyway.
-More info would be great.
Old Oct 30, 2003 | 05:09 PM
binkster's Avatar
Default Re: clicking help.. (-TRINiTRON-)
Click.... definetly a clicking... and I dont think its the injectors because If I leave the car out of gear and slowly increase the RPM's the engine sounds fine.. not even valve ticks.. thats why I thought it would be my CV joints.. but when im rolling out of gear there is no clicking.. only when im accelerating...
Old Oct 30, 2003 | 05:13 PM
Ricey McRicerton's Avatar
Okay, then it's transmission related. The sound only happens when it is in gear.
Old Oct 30, 2003 | 06:08 PM
binkster's Avatar
Default Re: clicking help.. (Ricey McRicerton)
yea
Old Oct 30, 2003 | 06:09 PM
binkster's Avatar
only in 1st and 2nd gear... I dont notice it after that.. it could be cause the wind.... mabey the teeth in the tranny?
Old Oct 30, 2003 | 06:27 PM
Could be..have you checked or changed your transmission fluid lately?? Try changing it out with some GM syncromesh and see how it works. Check for metal in the fluid when you drain it.
v8killaz
May 13, 2009 09:41 PM
crazybluecivic
Honda Civic (2001 - 2005)
Sep 18, 2007 02:55 AM
village_idiot
Sep 29, 2005 05:34 AM
sp00led
Sep 13, 2004 06:09 PM
