Oil pump Q's
Old Oct 28, 2003 | 11:37 AM
Trooper's Avatar
Default Oil pump Q's
Hey guys after seeing a few of my friends brand new oil pumps fail, what do you think about the upgrade parts from pro drive? also does any one know what pro drive's web site is?
Old Oct 28, 2003 | 12:00 PM
b18bturbo's Avatar
Default Re: Oil pump Q's (Trooper)
prodriveusa.com is there website.
There is no need for aftermarket gear. The prodrive gears also fail. The main cause of the failure is improper balance in the crank and pulley. Most people use aftermarket pulleys which cause the problem. Stick with factory dampner and oil pump and you should be fine.
Do seearch on here for oil pump in the archived section and you will also find some results.
Old Oct 28, 2003 | 01:12 PM
Trooper's Avatar
Default Re: Oil pump Q's (b18bturbo)
Both of my friends that had oil pump failures, were running Stock dampeners. We will never ever ever run lightened balancers
wickedplastikman
Feb 20, 2009 02:40 PM
SleepyHF
Mar 15, 2004 08:26 PM
PROFILES2000
Feb 25, 2002 01:17 PM
