How can you tell the difference between abs and non abs axles
Old Oct 28, 2003 | 10:19 AM
xrtdac
Guest
Posts: n/a
Default How can you tell the difference between abs and non abs axles
I just got my new set of stage 2 axles good for 425HP but the abs box wasn;t checked and I forgot what it is that distiguishes the difference betwen the two, abs and non-abs axles. Can someone show me or link me to something. pics maybe. please let me know.
Old Oct 28, 2003 | 10:38 AM
Katman's Avatar
Default Re: How can you tell the difference between abs and non abs axles (xrtdac)
there's a bumpy aluminum metal strip around the outter cup of the axle; the part of the axles that plugs into the wheel hub. That metal strip is read by the ABS sensor that lives on the innerside of the knuckle/hub assembly...
No metal strip = non-abs axles
Old Oct 28, 2003 | 12:04 PM
xrtdac
Guest
Posts: n/a
a bumpy aluminum metal strip around the outer cup of the axle. that narrows it down to the spline, a c ring and a whole other bunch of bumpy parts. got a pic at all??
Old Oct 28, 2003 | 12:18 PM
King Tut33's Avatar
Default Re: (xrtdac)
It is easy to tell. Just look at the end that goes into the hub and if you see a whiteish strip going around the entire joint with bumps on it, then it is an ABS axle. I don't have a pic, but it is very easy to tell.
Old Oct 28, 2003 | 01:00 PM
xrtdac
Guest
Posts: n/a
ahhh stil not helping here. I am axle illiterate at this point.
Old Oct 28, 2003 | 02:21 PM
PhatOptimo's Avatar
See that aluminum ring around the axle. He has his thumb on it. Its on the end of the axle where the nut is. HTH
Old Oct 28, 2003 | 03:08 PM
xrtdac
Guest
Posts: n/a
nice. thanks for the pic. thats awesome of ya.
Yep I have the wrong ones.
Old Nov 5, 2003 | 03:45 PM
cha chi's Avatar
you can put abs rings on the axles i believe
Old Nov 7, 2003 | 09:16 AM
xrtdac
Guest
Posts: n/a
just got the rings.
Old Nov 7, 2003 | 10:27 AM
GM2000ITR's Avatar
New User
ABS axles.....bligity Blam!!!!!
AznBlueBoy
Jul 16, 2009 10:53 AM
EG-SIXV-TEC
Dec 24, 2008 08:46 AM
nihad
Jul 21, 2007 09:38 PM
BB4
Mar 9, 2006 07:46 PM
TurboSI24
Oct 17, 2005 01:24 PM
