DA brakes on a EG??
I just recently came up on a deal for Teg Xsi (b16a version90-93) brakes for the front of my hatch....I assume these will work.....any one have anything to say otherwise??
Also....the same guy has a BB and MC set up (ABS) from a 90-93 GS.....would those work on my car just plug n play no flaring lines or anything?? Same deal on a prop valve......its non abs but for a DA chasis.......I need imput fast.....this deal is amazing.....all this for 200 bucks......thanks guys!!
-the front knuckles on the DA have seriously different geometry and cannot be used on an EG. you can use the DA calipers and rotors on 94+ integra knuckles though.
-the DA knuckles can barely be used on EF's without camber issues.
-if anything you want the non-ABS bb and mc and prop valve.
-thats not a great deal at $200 either...
-rear brakes of the DA are what we all want and thats why the DA guys have fronts only available!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCivicHMM »</TD></TR><TR><TD CLASS="quote">hmmm
I have the DA rear brakes and Trailing arms.....lolz
So thats a no on the DA front Knucle??? anyone else 2nd that??</TD></TR></TABLE>
how dare you question owen!
I also concur
Also, the shocks are the same height as the EG (fronts) but the diameter of the shock is more narrow on the DA than on the EG. So it's a bitch it put the EG/DC shock into a DA fork as it won't fit unless you expand the fork, and then the 14mm bolt doesn't like to go in to hold the fork on. Or if you put a DA shock into an EG fork, it's too small. The arms are curved totally different and the upper A-arms are also totally different. I have extra sets from DA/EF8 front clips and EG/DC front clips. Calipers are interchangable but they need their own brake pads, specific for the caliper.
.Also, the shocks are the same height as the EG (fronts) but the diameter of the shock is more narrow on the DA than on the EG. So it's a bitch it put the EG/DC shock into a DA fork as it won't fit unless you expand the fork, and then the 14mm bolt doesn't like to go in to hold the fork on. Or if you put a DA shock into an EG fork, it's too small. The arms are curved totally different and the upper A-arms are also totally different. I have extra sets from DA/EF8 front clips and EG/DC front clips. Calipers are interchangable but they need their own brake pads, specific for the caliper.
hmm aight guys...thanks...
I was just going to change the hubb so I could use the bigger calipers and rotors...keeep everything else...so nevermind.......
Yeah I'm still intrested in the BB and MC and prop valve set up if it fits...so I need answers..
GS 90-93 TEG - BB/MC and prop valve...all non abs..............will it be plug n play ??
gsrjunior
Nov 24, 2004 08:54 PM
92hybridAccord
Mar 8, 2004 07:46 AM
