DA brakes on a EG??
DA brakes on a EG??
I just recently came up on a deal for Teg Xsi (b16a version90-93) brakes for the front of my hatch....I assume these will work.....any one have anything to say otherwise??
Also....the same guy has a BB and MC set up (ABS) from a 90-93 GS.....would those work on my car just plug n play no flaring lines or anything?? Same deal on a prop valve......its non abs but for a DA chasis.......I need imput fast.....this deal is amazing.....all this for 200 bucks......thanks guys!!
Re: DA brakes on a EG?? (SloCivicHMM)
-the front knuckles on the DA have seriously different geometry and cannot be used on an EG. you can use the DA calipers and rotors on 94+ integra knuckles though.
-the DA knuckles can barely be used on EF's without camber issues.
-if anything you want the non-ABS bb and mc and prop valve.
-thats not a great deal at $200 either...
-rear brakes of the DA are what we all want and thats why the DA guys have fronts only available!
Re: DA brakes on a EG?? (owen_the_soyboy)
hmmm
I have the DA rear brakes and Trailing arms.....lolz
So thats a no on the DA front Knucle??? anyone else 2nd that??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SloCivicHMM »</TD></TR><TR><TD CLASS="quote">hmmm
So thats a no on the DA front Knucle??? anyone else 2nd that??</TD></TR></TABLE>
how dare you question owen!
I also concur .
Also, the shocks are the same height as the EG (fronts) but the diameter of the shock is more narrow on the DA than on the EG. So it's a bitch it put the EG/DC shock into a DA fork as it won't fit unless you expand the fork, and then the 14mm bolt doesn't like to go in to hold the fork on. Or if you put a DA shock into an EG fork, it's too small. The arms are curved totally different and the upper A-arms are also totally different. I have extra sets from DA/EF8 front clips and EG/DC front clips. Calipers are interchangable but they need their own brake pads, specific for the caliper.
Re: DA brakes on a EG?? (Newman)
hmm aight guys...thanks...
I was just going to change the hubb so I could use the bigger calipers and rotors...keeep everything else...so nevermind.......
Re: DA brakes on a EG?? (Egone)
Yeah I'm still intrested in the BB and MC and prop valve set up if it fits...so I need answers..
GS 90-93 TEG - BB/MC and prop valve...all non abs..............will it be plug n play ??
gsrjunior
11-24-2004 08:54 PM
92hybridAccord
03-08-2004 07:46 AM
