cheapest LS/vtec setup?
Old Oct 27, 2003 | 10:09 PM
Wazup's Avatar
Default cheapest LS/vtec setup?
im lookin to do an lsvtec setup in the future, and i was wondering if you guys can suggest the cheapest way of doing it. the motor is gonna have to be a 97 and up since my car is a 97. i was thinking of:
b18b block
stock b16 head
stock LS rods
b16 pistons (no modification necessary?)
ARP rod bolts
VTEC oil pump
VTEC water pump (necessary?)
anyway, just figured that may be a simple build with stock parts. not looking for too much power.. but then again i guess itll add up anyway since id have to get it built and tuned...
any thoughts on a setup?
Old Oct 28, 2003 | 09:06 AM
HKJ's Avatar
HKJ
Default Re: cheapest LS/vtec setup? (Wazup)
cheap + building a motor = disaster.
honestly dude, if you cheap out, it's gonna blow up on you. and no, the motor doesn't have to come off a 97 ls, it can also come off a 94, 95, etc etc.
save yourself the trouble and get a gsr motor.
Old Oct 28, 2003 | 09:36 AM
thid92's Avatar
can I haz?
you will be fine using b16 pistons
the only way of building a motor is by spending money on all the crutial parts such *** bearings, pistons, rods and headgasket. there is not such thing as a cheap reliable motor.
always when building a motor, over estimate the price by atleast 30%. i learned the hard way, i have over 10k into my motor and it wont be ready until this spring.
i had only planed on putting 5k into it but then decided that a turbo would be the way to go. when going turbo with a B20 you need new sleeves and so on.
i suggest that you search as much as possible and reaserch on the build up that you are planing on before anything.
Modified by thid92 at 3:00 PM 10/28/2003
Old Oct 28, 2003 | 09:42 AM
smnowell's Avatar
Default Re: (thid92)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thid92 &raquo;</TD></TR><TR><TD CLASS="quote">good luck useing b16 pistons that are 81mm in a block that is 84mm.
i suggest that you search as much as possible and reaserch on the build up that you are planing on before anything. </TD></TR></TABLE>
wow, just from that statement, i would never listen to you. B18B blocks are 81mm, same as B16 block, B18C block.... B20 blocks, however, are 84mm...
Old Oct 28, 2003 | 10:05 AM
thid92's Avatar
can I haz?
^^^ pistons edited . i am a ******* moron
Modified by thid92 at 2:58 PM 10/28/2003
Old Oct 28, 2003 | 10:06 AM
thid92's Avatar
can I haz?
Default Re: (b16a ferio)
since your trying to flame me for my input why dont you write yours?
Old Oct 28, 2003 | 10:41 AM
Wazup's Avatar
thanks for the input...
yes, i do need a 97 and up for smog purposes...
and i do realize that, in a sense, there isnt a cheap way to build a motor.. but maybe i didnt phrase it the right way... i just meant what would be a relatively cheap setup using stock parts... notice i didnt *** expensive cams or headwork into the setup... if i were to do this setup, i would definitely have it built by a reputable engine builder and tuner...
then again, i guess a GSR motor would be a better way to go... i just thought that using cheaper, stock parts would maybe yeild a cheaper price than a stock gsr...
Old Oct 28, 2003 | 10:55 AM
WhiteEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thid92 &raquo;</TD></TR><TR><TD CLASS="quote">duh i thought he was talking about the B18C block </TD></TR></TABLE>
B18c is still 81mm
Old Oct 28, 2003 | 11:20 AM
eddiecut's Avatar
Default Re: (WhiteEG6)
i think he is sayin that he needs a 97 and up because he wants to pass smog, dont cheap out bro it will cost you more in the long run...
KornyCivic
Nov 15, 2005 12:41 PM
fed
Feb 15, 2005 03:45 PM
juicedricer
Aug 17, 2003 01:38 PM
xmattoxx
17
Jan 12, 2003 01:47 PM
RexB16
Feb 12, 2002 04:11 AM
