LS B18B head, header, cat, 3rd/4th gear stack, obd1 injector clips, and AEM FUEL PRESSURE REGULATOR!
Old Oct 27, 2003 | 09:49 PM
DIRep972's Avatar
Smarter than you
Default LS B18B head, header, cat, 3rd/4th gear stack, obd1 injector clips, and AEM FUEL PRESSURE REGULATOR!
Ok. i had a couple posts going about this stuff. Sorry if u replied and I did not get back to you the posts were deleted because you are not allowed to make mulitiple posts for seperate items.. here is what i have left:
-LS B18B head. no valve cover, cams, or intake manifold. has all vavletrain and valves, bought it to put big LS turbo cams in it and no longer need it cause I went GSR.
100$ shipped
-OBD1 stock honda injector clips for sale.
25$ shipped
-AEM fuel pressure regulator. Needs a diaphram. The regulator retails for 225.00 and you can get the diaphram for 20$ from AEM. I bought it because I needed a diaphram right away and could not wait for one from AEM. Planned to get one before i sold it but never ended up buying one and it is just sitting in my room and I want to get rid of it. It is brand new.
100$ shipped
-LS 3rd/4th gear stack. I bought this to rebuild my old LS tranny but I ended up getting a GSR so I no longer need it. If ur 3rd gear is grinding this is what you need to fix it.
100$ shipped
-LS B18B header and catylitic converter. These are just sitting in my garage and I need to get rid of them as well.
50$ shipped SOLD!!!!!!
thanks
chris
Modified by DIRep972 at 9:28 AM 10/29/2003
Old Oct 28, 2003 | 07:17 AM
DIRep972's Avatar
Smarter than you
Default Re: LS B18B head, header, cat, 3rd/4th gear stack, obd1 injector clips, and AEM FUEL PRESSURE REGULA
ttt
Old Oct 28, 2003 | 07:22 AM
B18c1EKCpe's Avatar
do you have any wires attached to the injector clips?
Phil
Old Oct 28, 2003 | 07:25 AM
DIRep972's Avatar
Smarter than you
Yep they have wires, about 5" worth.
Old Oct 28, 2003 | 08:56 AM
B18c1EKCpe's Avatar
Just to make sure its a total of four of them and they still work properly right?
Thanks
Old Oct 28, 2003 | 08:58 AM
DIRep972's Avatar
Smarter than you
yep, four total and they all are good working condition.
chris
Old Oct 28, 2003 | 11:22 AM
DIRep972's Avatar
Smarter than you
bump
Old Oct 28, 2003 | 05:39 PM
DIRep972's Avatar
Smarter than you
ttt
Old Oct 28, 2003 | 09:46 PM
DIRep972's Avatar
Smarter than you
bump
Old Oct 29, 2003 | 07:02 AM
95hbMatt's Avatar
sup man...what condition is the cat in?? will it pass a smog test? let me know, thanks! Matt
Old Oct 29, 2003 | 08:28 AM
DIRep972's Avatar
Smarter than you
sorry the cat and header just sold. but yep, it was in perfect condition.
chris
Old Oct 30, 2003 | 11:31 AM
DIRep972's Avatar
Smarter than you
ttt
Old Oct 30, 2003 | 08:28 PM
DIRep972's Avatar
Smarter than you
ttt
Old Oct 31, 2003 | 03:20 PM
DIRep972's Avatar
Smarter than you
bump
ek98gsr
Feb 1, 2014 09:17 PM
DARKTEG_
Sep 24, 2006 08:00 AM
Wazup
Oct 24, 2005 04:06 PM
ExplicitSpeed
Aug 3, 2004 06:45 PM
