Which pinouts on the ECU for o2 sensor???? 93 accord....
need to know which pinouts on the ecu for direct wiring the o2 sensor to the ecu itself... its a 93 accord LX 5 speed
some one has to know this........ i need to direct wire my o2 sensor to my ecu, but dont know which wires to tap into at the ecu....
Pretty sure its the same as any obd-1 wiring. Not sure where you can find it but if you can find it on someone's site it is the same as the b-series wriring pinouts in the civics and integras. Good luck.
here are some pinouts for civics
http://www.hondaswap.com/articles/viewer.php?id=47
and here for preludes(wich should be the same, but not sure)
http://www.hondaswap.com/articles/viewer.php?id=29
just 02
just 02
ok, so i should only have to actually run 2 wires, for the actual o2 sensor signal, and the heater signal, right?? and th eother 2 are just power/ ground? or what??
it just snowed a little bit here today, so i have to put my acura away soon, but my winter car isnt running very good, cuz of this wiring situation i wont get into... haha. thanks
1992cxcivicEG
Dec 18, 2009 07:42 AM
eagleclawracing
Jun 28, 2006 09:22 AM
bdicustoms
May 27, 2003 06:30 PM
