pistons or just shave
Old Oct 27, 2003 | 06:31 PM
sikcrx80's Avatar
Default pistons or just shave
well i am confused now
i was thinking about doing CTR pistons in my b16 and then shaving my head to up comp even more... i just talk to a buddy and he said save my money and just shave the head and dont put pistons in it. it is cheaper and u can do the same thing.
i dont know how it will work.
what do u all think about it?
Old Oct 27, 2003 | 06:40 PM
mmuller's Avatar
Mad Scientist
Default Re: pistons or just shave (sikcrx80)
ahh, well you can only shave the head so much...so if you swap pistons+shave the head=more comp. than just shaving
Old Oct 27, 2003 | 06:46 PM
sikcrx80's Avatar
thats what i thought. i want some where around 11.5.1 good round #.
Old Oct 30, 2003 | 05:26 PM
klnteg's Avatar
Just be careful, if you raise your compression too high you will have problems with pump gas. What happens when you are out of fuel and the only gas station has 87 Octane? You better carry a bottle of Octane booster with you just to be safe.
Old Nov 4, 2003 | 04:26 AM
1700anddroping's Avatar
Default Re: (klnteg)
why not take the center layer out of the head gasket.you can save your head and piston.if you want really high comp. take one layer and mill head 30ths and use ctr's that would make you a pretty mean all motor with stock parts.
Old Nov 4, 2003 | 08:50 AM
kommon_sense's Avatar
Default Re: (1700anddroping)
I don't think that you can safely shave enough off of your head to get up to 11.5:1. You are going to have to get pistons.
Assuming that you can, I would probably still opt for pistons, or shave a spare head. Problem with shaving is that once you shave the head, you can't undo it.
Old Nov 4, 2003 | 09:00 AM
owen_the_soyboy's Avatar
Default Re: (kommon_sense)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kommon_sense &raquo;</TD></TR><TR><TD CLASS="quote">I don't think that you can safely shave enough off of your head to get up to 11.5:1. You are going to have to get pistons.
Assuming that you can, I would probably still opt for pistons, or shave a spare head. Problem with shaving is that once you shave the head, you can't undo it.</TD></TR></TABLE> I agree.
once you shave a head enough to make a huge difference in compression, you will need to compensate with adjustable cam gears since the difference in height will effect timing belt and timing cams to the crank..... ugh.
Old Nov 4, 2003 | 10:33 AM
Kendall's Avatar
I have never had more problems with a motor than when I had a milled head on my b16a. Pistons work, thinner gaskets work, and they are both able to be undone. I had to sell my milled head and get a stock one, after I did that, everything worked great.
tomlinson619
Apr 15, 2006 03:26 AM
canada-civic
Mar 1, 2006 07:50 AM
b20vtech
14
Dec 8, 2005 09:52 PM
sikcrx80
Oct 28, 2003 05:41 PM
gsr98vtec
Jan 4, 2002 05:25 PM
