what cams should i go with....
Old Oct 27, 2003 | 04:44 PM
tegnchewy's Avatar
Default what cams should i go with....
I have a 01 itr motor...and i want to upgrae my cams but dont know what to go with...plus if i go wit the new cams should i replace everything else in the head...but i dont want to change any of the compression...and once i get them in i plan on goin to ITB's...so i need some in put...once i get all of it done im goin to run a standalone system...anyone?
Old Oct 27, 2003 | 05:13 PM
Rob Dizzle's Avatar
Default Re: what cams should i go with.... (tegnchewy)
unless you have a really good header, intake, tuning program, injectors, cam gears and extra money for tuning. then its a waste of money to get cams
anyone who says "skunk2, ef-1, toda bla blah" are retards because no one has any idea what your setup is.
u want reliability, peak dyno hp #'s, phat midrange???
Old Oct 27, 2003 | 05:18 PM
tegnchewy's Avatar
well i got all of what u listed...aem cam gears, reactive header<--waitin for new one to arive.. rail, reg, and usin standalone
Old Oct 27, 2003 | 05:28 PM
Rob Dizzle's Avatar
Default Re: (tegnchewy)
what header and what stand alone?
Old Oct 27, 2003 | 05:31 PM
tegnchewy's Avatar
micro-tek...uses plasma scanner and ****...pretty sweet...and header not sure what one to get yet...gotta pick between jdm dc or this new one that twists and turn cant remember the name
Old Oct 27, 2003 | 08:35 PM
TwoRedEGgs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegnchewy &raquo;</TD></TR><TR><TD CLASS="quote">micro-tek...uses plasma scanner and ****...pretty sweet...and header not sure what one to get yet...gotta pick between jdm dc or this new one that twists and turn cant remember the name
Get a good header b4 u get cams, that way when u get the cams they will be able to flow to thir fully potential.
Headers: DTR(www.DTRFAB.com) SMSP, Hytech. Any of these will give you a huge power jump, no BS
Old Oct 29, 2003 | 07:39 PM
tegnchewy's Avatar
got a new hearder today...comptech...now what cams damint
Old Oct 29, 2003 | 07:41 PM
omega11855's Avatar
i had a sorta similiar setup once and tuned s2s2 made nice power up top for me
Old Oct 30, 2003 | 04:25 AM
TGUNNER's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegnchewy &raquo;</TD></TR><TR><TD CLASS="quote">got a new hearder today...comptech...now what cams damint</TD></TR></TABLE>
Which header?? Hopefully the Race header.
Old Oct 30, 2003 | 01:24 PM
tegnchewy's Avatar
yah ill post a pic up
Old Oct 30, 2003 | 01:35 PM
tegnchewy's Avatar
Default Re: (TGUNNER)
go there to see pics... http://www.autocarparts.com/part/253/10
Old Oct 30, 2003 | 01:41 PM
turbo*s2k's Avatar
well since you want to keep your compression the same... I personally like the skunk2 stage 1 cams. Maybe replace the inner valve springs with stiffer one's, get your stand alone, tune the car, and extend the redline a bit.
Old Oct 30, 2003 | 02:03 PM
tegnchewy's Avatar
Default Re: (TurboChrgd_Civic)
finally thank you...even when i go the the ITB's?
phelpsj2
Mar 21, 2012 07:44 PM
Type RS
Feb 1, 2003 08:11 PM
el_Presidente
Jan 23, 2002 06:21 PM
98gsr
Sep 15, 2001 07:35 PM
