which pistons would be best for itr
Old Oct 27, 2003 | 04:20 PM
IH82LOSE's Avatar
Default which pistons would be best for itr
i was wanting to see what piston you all would recommend for higher compression. would i be able to use the same rods or would i have to get some aftermarket ones. anyones opinions would be nice.
Old Oct 28, 2003 | 01:13 PM
junya16's Avatar
Default Re: which pistons would be best for itr (IH82LOSE)
keep yours and get a thinner headgasket...that should yield around 11:9:1 w/ somethin like a mugen hg and thats plenty for the street...
Old Oct 28, 2003 | 01:33 PM
Rob Dizzle's Avatar
Default Re: which pistons would be best for itr (junya16)
custom spec wiseco from IB or rlz.
Or cp pistons from rocket is prolly the best 3 choices
Old Oct 28, 2003 | 02:54 PM
len's Avatar
len
If you currently have a stock bottom end and want to raise compression, I'd recommend getting CTRs oversized and stock headgasket.
I was never a fan of using thinner headgaskets to up the compression. It always seemed like a band-aid fix to me.
Old Oct 29, 2003 | 10:49 AM
junya16's Avatar
Default Re: which pistons would be best for itr (len)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by len &raquo;</TD></TR><TR><TD CLASS="quote">
I was never a fan of using thinner headgaskets to up the compression. It always seemed like a band-aid fix to me. </TD></TR></TABLE>
I like bandaids..
Old Oct 29, 2003 | 12:51 PM
hYpE-R-29's Avatar
bump i would like to know also what would be the easiest way to up the compression for a ITR
Old Oct 29, 2003 | 01:10 PM
TrboInteg's Avatar
CTR's get the from me!
Old Oct 29, 2003 | 08:12 PM
Tadeh's Avatar
Default Re: which pistons would be best for itr (TrboInteg)
CTR.
Old Oct 30, 2003 | 03:12 PM
IH82LOSE's Avatar
Default Re: which pistons would be best for itr (tadeh)
how much more would the ctr pistons bump the compression up. would i have to bore anything out or can i just take the itr ones out and put the ctr in
Old Oct 30, 2003 | 06:52 PM
Padawan's Avatar
Darth ModerVader
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by junya16 &raquo;</TD></TR><TR><TD CLASS="quote">keep yours and get a thinner headgasket...that should yield around 11:9:1 w/ somethin like a mugen hg and thats plenty for the street...</TD></TR></TABLE>
On an otherwise stock ITR, the compression actually won't be anywhere near that with just the addition of the Mugen gasket.
Old Oct 30, 2003 | 07:26 PM
philafelman's Avatar
Default Re: which pistons would be best for itr (Padawan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Padawan &raquo;</TD></TR><TR><TD CLASS="quote">
On an otherwise stock ITR, the compression actually won't be anywhere near that with just the addition of the Mugen gasket. </TD></TR></TABLE>
yeah, i agree, should be around 11.2:1.
Old Oct 30, 2003 | 09:04 PM
Padawan's Avatar
Darth ModerVader
Default Re: which pistons would be best for itr (philafelman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philafelman &raquo;</TD></TR><TR><TD CLASS="quote">yeah, i agree, should be around 11.2:1.</TD></TR></TABLE>
~ 10.9:1
Old Oct 30, 2003 | 09:42 PM
dirty_d_cx's Avatar
if you go with a reduced head gasket (ie. 1 layer)
and jdm b16b pistons your compression would be at 12.44:1
usdm b16a 11.73:1
jdm b16a 11.97:1
http://www.c-speedracing.com how-to section
Old Oct 31, 2003 | 03:53 AM
01ytr's Avatar
Default Re: which pistons would be best for itr (dirty_d_cx)
Go with a 11.5:1 set up. That is actually the best set up for pumped gas. Then change your valve train, cams and cam gears.
Old Oct 31, 2003 | 10:43 AM
(JON)'s Avatar
jdm itr pistons and mugen or spoon headgasket will yeild 11.4??:1 compression! ctr pistons and stock head gasket would yield 11.6:1 compression. anything higher than that on 91 pump gas is recommended to retard timing!
Old Oct 31, 2003 | 11:37 AM
TodaSi's Avatar
Default Re: (DaStyle)
Toda goodness.
BTW, I have a new set with rings and wrist pins for sale.
j0nb0y22
Oct 3, 2007 12:17 PM
bseriesEF
10
Nov 13, 2006 04:37 PM
94gsr18kid
10
Jan 25, 2005 05:35 PM
gregsr
Jul 20, 2003 04:39 PM
I_know
Dec 21, 2002 07:07 AM
