just installed shocks/springs... ride is bouncy as hell... help!
Old Oct 27, 2003 | 02:08 PM
rody084's Avatar
Default just installed shocks/springs... ride is bouncy as hell... help!
I have a 1990 Integra and I just had sum Ground Control Coilovers (350F/300R) and some Tokico Illuminas installed onto my car by a reputable shop.
The car is lowered about 1" all around and the shocks are all set at 5.
The ride is bouncy as hell... any little unevenness in the road and the car starts bouncing around, i was going about 80mph on the highway, hit a uneven surface and i felt like my car was gonna lift off the ground...
The shocks and the springs are all brand new... bumpstops were cut 1/2... anyone know what could be wrong with my setup? it almost feels like the sohcks arent doing anything at all
Old Oct 27, 2003 | 02:14 PM
Hybridize's Avatar
Are you sure they aren't on 1 instead of 5? I'd try adusting the shocks because that's clearly where the problem lies. If you can't get them to harden up, take em back, they sold you blown shocks....
Old Oct 27, 2003 | 02:16 PM
b20turbojason's Avatar
Default Re: just installed shocks/springs... ride is bouncy as hell... help! (rody084)
right on
Old Oct 27, 2003 | 02:24 PM
Don Napier's Avatar
Import Alliance
Default Re: just installed shocks/springs... ride is bouncy as hell... help! (b20turbojason)
setting shocks to stuff will make the ride bouncy. Set the shocks to a lower setting(softening them) and that will fix your problem.
Old Oct 27, 2003 | 02:52 PM
rody084's Avatar
Default Re: just installed shocks/springs... ride is bouncy as hell... help! (egCivicDon)
hmm... so i want them on a softer setting to avoid bouncyness?
ok, so i have heard mixed facts about this... which is the stiffest setting? 1 or 5?
Old Oct 27, 2003 | 03:07 PM
Hybridize's Avatar
5 is the stiffest, 1 is the softest.
My rex was set to 4 in front, 5 in the rear... No bounce...
Old Oct 27, 2003 | 03:18 PM
Hybridize's Avatar
Also, IMO the 1-3 settings are useless. Far too soft, u'll be bouncing down the road for miles after hitting a pebble. 4-5 is where it's at on the illuminas for a performance ride. 3 might be acceptable if you like a dainty ride.
HTH
Old Oct 27, 2003 | 03:21 PM
Hybridize's Avatar
Oh and to answer your question...
Soft = Bouncy
Firm = Harsh.
No more whoring of this thread from me.
Old Oct 27, 2003 | 05:11 PM
Don Napier's Avatar
Import Alliance
Default Re: (Hybridize)
I think he is calling stiffness bouncy. I kept my back at 3 and the front at 2 most of the time unless I wanted to drive crazy and then I would set them to 4 and 5.
Old Oct 27, 2003 | 05:38 PM
rody084's Avatar
Default Re: (egCivicDon)
i consider soft to be all bouncy... and i consider stiff to be not bouncy... is that the right way of thinking about it?
suspension stuff confuses the hell out of me for sum reason.
i just tried adjusting my fronts to 3 and it seems to be bouncing a little less... so now when i get a chance to take apart the whole rear panel im gonna try adjusting the rears to 3 also and i'll let u all know...
question: performance-wise... do i want stiffer in the back or in the front?
EDIT: NM, i found this great site with info on what every mod will do to your understeer/oversteer... http://users.telenet.be/miata/...n.htm
Modified by rody084 at 2:54 AM 10/28/2003
Old Oct 27, 2003 | 07:08 PM
sleepyEK's Avatar
Default Re: (rody084)
i think the best way to eliminate bounce is to go with double adjustable shocks, and set the rebound to stiff. you also have to consider whether or not the car and shocks are under or over sprung.
Old Oct 27, 2003 | 07:17 PM
tinkerbell's Avatar
Default Re: (sleepyEK)
remember that springs absorb the bumps of the road and that the socks absorb the springs motion...
then you can see that a bouncy car has too soft a shock...
and a hard stiff car has a firm enough shock...
fairly simplist - i know, but gives a approximate picture...
go here for details: http://www.turnfast.com/tech_h...lasso
for that site!
t..
Old Oct 28, 2003 | 06:29 PM
rody084's Avatar
Default Re: (tinkerbell)
PROBLEM SOLVED...
SOLUTION= im a dumbfuck
i was under the impression that the shocks werent dampening the springs... when what was actually going on was that they were REALLY dampening them and that i was feeling every groove and uneveness of the road...
the guy at the installation shop made me see the light
so i jsut adjusted them to 3 and its a great ride in teh city now... deff gonna go back up to 3 when i hit up a highway on a road trip tho
Old Oct 30, 2003 | 08:56 PM
mckenzie's Avatar
it doesn t help since u live in frisko, when i go there damn its like a nightmare ..my sustec front lower tie bar is silver instead of blue and the plaque on it is missing now haha
Old Oct 31, 2003 | 05:30 AM
Don Napier's Avatar
Import Alliance
Default Re: (egMee)
glad to hear you took my advice...I had the same setup as you do.
Old Nov 6, 2003 | 05:03 PM
vtekstorm's Avatar
i got a 1.3 drop all around wit kyb adjustable shocks and i got my fronts set on 3 and my rears set on 5
bigdogadam
Jan 13, 2009 08:07 PM
brodyl05
Mar 11, 2007 04:53 PM
bb4socal
Nov 23, 2005 05:35 AM
RICEBURNER1406
Mar 22, 2002 07:01 PM
Integra187
Dec 1, 2001 01:50 AM
