Help me troubleshoot my 94 Civic EX please: Car wont start
Old Oct 27, 2003 | 12:31 PM
T-RO's Avatar
Default Help me troubleshoot my 94 Civic EX please: Car wont start
94 Civic EX Stock D16z6
Ok, driving down the highway this morning at about 80mph. All of a sudden the RPM dropped down from 3500 to 0. I lost engine power. I pulled over and the car wont start up again.
Engine DOES turn over
No ECU codes
I still have battery power
Fuel Pump DOES turn on
I DO have power at Fuel Pump "Connector" (connector to the FP Relay)
I have NOT tested the Fuel Pump relay (under dash, drivers side) - Dont know how
Thanks!
Old Oct 27, 2003 | 12:34 PM
CNY Hatch's Avatar
Same thing happened to my 93 Si a while ago... come to find out my coil went bad... check for spark
Old Oct 27, 2003 | 01:04 PM
Perfectionist's Avatar
Default Re: Help me troubleshoot my 94 Civic EX please: Car wont start (T-RO)
If you hear the pump come on. the main relay is OK on that half. The other half powers the injectors.
I hate to ask, but is the cam turning? (Broken timing belt)
Old Oct 27, 2003 | 01:06 PM
Archidictus's Avatar
Unceasing Measure
Default Re: Help me troubleshoot my 94 Civic EX please: Car wont start (Perfectionist)
Broken timing belt would've made some noise : bad noise.
It's probably your distributor. You can take it apart and troubleshoot the constituent parts or you can just get a new one. The MSD Blaster external coil and corresponding cap work out well if it is, indeed, your coil.
Old Oct 27, 2003 | 06:09 PM
T-RO's Avatar
Ok, i'm gonna start checking the distributor next then.
Old Oct 27, 2003 | 06:47 PM
Cynical 1's Avatar
Check fuel, spark, compression. Did your timing belt snap? Is your air filter totally clogged?
Start checking the little things. Check fuses... etc...
Old Oct 27, 2003 | 07:26 PM
T-RO's Avatar
Well I dont think fuel is thr problem. I checked and I do have fuel pressure.
I pulled the plugs and they look ok but need to be replaced.
I also pulled the distributor cap and rotor. I'm gonna take them to Autozone in the morning so they can look at them. I dont know if they are bad or not.
I did just remember that in the past 2 weeks or so the car was becomming harder to start. Took longer to fire up. So mabye it is something spark related.
Old Oct 29, 2003 | 12:08 PM
civicmon's Avatar
I had the same exact thing happen on my 96 civ...It's probably the ignition coil. See if you have spark. This is common in civics.
Old Oct 29, 2003 | 12:18 PM
dunkd's Avatar
yup, sounds like an ignition problem to me.
Old Oct 29, 2003 | 06:56 PM
T-RO's Avatar
I think it is my Ignition Control Module. I'm trying to track down a cheap one now to see if that fixes it.
Old Oct 31, 2003 | 02:47 PM
T-RO's Avatar
I tested my Ignition Coil like it says in my Haynes manual and it says its fine. Plugs are fine also.
Old Oct 31, 2003 | 06:40 PM
Snail Tuning's Avatar
Default Re: (T-RO)
look at the rotor and cap if u see white makes like white burns they are bad.
also my hexnut on my rotor came out and caused my car to come to a complete hult. did your rotor spin freely before u took it off?
Old Oct 31, 2003 | 07:15 PM
T-RO's Avatar
I dont remember if the rotor spun or not. If I put it back on can I test it? Just spin it around?
Would that cause the car to die immediatly like mine did?
The guys at the Autoparts shops I've been too have suggested i\that its the ICM.
Old Oct 31, 2003 | 07:56 PM
Default Re: (T-RO)
did u remove a nut when u took the rotor off? my hex nut came out. so my rotor spun.
Old Nov 1, 2003 | 02:52 AM
T-RO's Avatar
Yes, that nut was still in place.
Yama801
Jan 4, 2018 03:38 PM
JDM-sol 89
Feb 14, 2012 01:50 PM
FSS13foxtrot
Jun 15, 2010 12:58 AM
Ricky80b
11
Aug 30, 2009 09:06 PM
