INJECTOR QUEST
I was just wondering what is a better injector. 12-13 ohm. or the 2-3 ohm. Not sure what to use. and what injectors would you recommend for my setup. b16 block with stock internals, ITR head, Iceman intake, AN-R compact header, B16 Intake Manifold, STR fuel Rail, Holley FPR,MSD Digital 6 plus, MSD blaster coil. I was thinking RC 270's or 290's. Thank you for your help. Jason
2-3 ohm. Those are the peak and hold injectors that our cars use. The higher voltage ones are saturated injectors. I would just stick with the stock 240cc injectors for your application though.
