dX dUAL point to SOHC VTEC crx? Can I use a 92-95 si hatch harness? what harnes?
Old Oct 27, 2003 | 12:12 PM
Spooled1.6L's Avatar
Default dX dUAL point to SOHC VTEC crx? Can I use a 92-95 si hatch harness? what harnes?
Looking to do the swap soon, need all parts including motor let me know if you have anything ofr sale
Old Oct 27, 2003 | 01:53 PM
Redline130's Avatar
Default Re: dX dUAL point to SOHC VTEC crx? Can I use a 92-95 si hatch harness? what harnes? (Spooled1.6L)
The easiest thing to do is to use your existing harness and add the necessary wires. First off you'll need to add the wiring for MPFI. Then depending on which ecu you are planning on using for the motor, will dictate where you go from there. If you plan on converting to OBD1 and using a P28 ecu, then you'll need an OBD0 to OBD1 conversion harness.
Old Oct 27, 2003 | 02:39 PM
Default Re: dX dUAL point to SOHC VTEC crx? Can I use a 92-95 si hatch harness? what harnes? (Redline130)
thanks, what all do you have done to your b16 in the rex
VegasEFHB
10
Oct 15, 2014 12:22 PM
Didly
Mar 10, 2009 04:10 AM
93(Civic)EG6
Jul 18, 2007 09:51 AM
blacksheep
May 27, 2003 12:29 PM
SOcalistreetracer
Jun 1, 2002 08:18 AM
